Latest: heikkisj
Overall: 17126
Online Now [530]:
Visitors: 529
Today: 34503
Total: 100367459
Forums › The Car › 206 Problems › Overheating in traffic
Go to page 1, 2, 3  Next
ahfeckit
PostPosted: Fri Dec 30, 2011 9:16 am Up
I have a 02 1.1 206 which is running fine in general. But if I get stuck in traffic for anything over 30 minutes the temperature gauge rises almost to the red and the only way to cool it down is to turn the engine off when Im stopped.
blah
PostPosted: Fri Dec 30, 2011 9:18 am Up
Fan isn't working. You need to check the relays and resistors. Read the live data to check the ECU is trying to turn the fan on at 92oC (i think second stage cooling is)
If you need a new relay and resistor, I have one that I have just removed from a 206, and it was working when tested.
glenpring
PostPosted: Fri Dec 30, 2011 9:31 am Up
lee do you own a dealership you know so much and have so many parts lol
PostPosted: Fri Dec 30, 2011 9:33 am Up
Nah Laughing
Just have my finger in a few pies around the world Laughing
Twidly
PostPosted: Fri Dec 30, 2011 9:39 am Up
*a*******s you mean Lee Wink
PostPosted: Fri Dec 30, 2011 9:47 am Up
Yeah I know and you love it Wink
Laughing
namgaj
PostPosted: Fri Dec 30, 2011 11:02 am Up
More like Lees garden is a scrapyard Wink haha
4.0 V8 S-Type Jaguar
PostPosted: Fri Dec 30, 2011 11:46 am Up
Also check the wiring to the relays. The relays can look fine but the wires to the relay terminals can be all corroded.
D4NTP
PostPosted: Fri Dec 30, 2011 1:11 pm Up
save money, put the heater on flat out.
nemesislee
PostPosted: Tue Jan 03, 2012 2:12 pm Up
hello, im having roughly the same problem. my car is fine most of the time but the odd occassion it will reach at least 100°c then the fan kicks in. it cools it back down to 90°c then eventually rises again. ive looked at the main fan at the front and when im driving and the temperature is at about 80°c its stationary? is it supposed to be moving? its doing my nut in im always watching it!!! Sad
thanks
peugeot 206 silver 1.4ltr lx
Deckchair5
PostPosted: Wed Jan 04, 2012 4:07 am Up
nemesislee
Sounds like your slow speed fan circuit isn't working and the fast speed fan circuit is the only one remaining which will cut in at the higher temp. Pretty common fault so need to check relay/ wiring/ slow speed resistor. It's all stuck out the front to air cool the resistor but that means it's open to all the weather so corrosion is a problem there
Your fan shouldn't be working at all temps, it works on slow speed as the first temp limit is reached, slower motor speed achieved through a resistor, and then on full speed at the higher limit
nemesislee
PostPosted: Wed Jan 04, 2012 6:03 am Up
Thanks il have a look into that Smile its been ragging my head trying to find the problem. iv brought a standard airbox to replace the induction filter im determined to get it fixed Smile
thanks
nemesislee
PostPosted: Wed Jan 04, 2012 6:21 am Up
where would i buy replacements from? ive looked on ebay and euro car parts but nothing Sad
PostPosted: Wed Jan 04, 2012 6:44 am Up
www.peugeot.co.uk/deal...index.html
Lecktorious
PostPosted: Wed Jan 04, 2012 7:25 am Up
Trade Rating: +59
What a ridiculous suggestion.
'98 Nile Blue 306 GTi 6
Page 1 of 3
