Latest: lio94
Overall: 17181
Online Now [150]:
Visitors: 149
Today: 43091
Total: 141061391
Forums › The Car › Request a how-to › Decarbon engine
Decarbon engine
Forum IndexRequest a how-to
Go to page Previous  1, 2
Majid
PostPosted: Thu Jul 04, 2013 3:01 am Reply with quote Up
Hi
It is a ticking noise
Serviced car
Changed timing belt and auxiliary belt inc water pump
Peugeot 206, 1.6, 16 valve
2003
Majid
PostPosted: Thu Jul 04, 2013 3:02 am Reply with quote Up
By the way when I try accelerate it hesitates and then goes
2003
eddie206
PostPosted: Fri Jul 05, 2013 8:32 am Reply with quote Up
Edward wrote:
Just drive it. Pottering round town at low revs and idling a lot can coke them up. Just use it at higher revs with decent throttle openings and it will be fine.
This is hardly just sayin the engine is used a little..drive it and use higher revs..ive suggested a good thrash for curing some things but driving it at high revs when thete could be a serious problem..is not the right thing to do until you know that the engine wont pop...
eddie206
PostPosted: Fri Jul 05, 2013 8:40 am Reply with quote Up
Fortunately he has now serviced the car and done the belt but we did not know this when you suggested to drive it hard earlier...
Anyway..now the belts done and that a good thrash might be called for mid gears..high revs prolongued for upto 30mins three or four times..
The ticking you mention may be normal engine noise possibly alternator or similar..but as for the poor acceleration response and hesitation u need to take the icv off and give it a proper clean..strictly follow the HOW TO on the matter and go from there ...respond
Page 2 of 2
  Quick Reply
Username:
Message:
Quote the last message
