Latest: DanDan17
Overall: 17128
Online Now [48]:
Visitors: 47
Today: 21035
Total: 100419205
Forums › The Car › 206 Problems › Quick fan help
Quick fan help
weejoe86
PostPosted: Thu Jul 04, 2013 4:06 pm Up
Hi
I have recently had my cooling fan wiring repaired and upon checking to confirm that it is fixed by switching on the air con to see if the low speed fan will kick in without letting it warm up. It doesn't kick in. I know the air con probably needs re-gassed, but have read that it should still kick in? Is this correct? The green light comes on when I press the button. But that is all.
2.0 SW HDi Quiksilver
PostPosted: Thu Jul 04, 2013 4:13 pm Up
I didn't even know there was a low speed fan or that it was supposed to come on with the AC.
PostPosted: Thu Jul 04, 2013 4:18 pm Up
If the AC isn't working the cooling fan won't be activated.
weejoe86
PostPosted: Thu Jul 04, 2013 4:23 pm Up
cheers Mr BSI
weejoe86
PostPosted: Mon Jul 08, 2013 5:50 pm Up
hey guys further help needed. Went out today and noticed the temp guarpge get to the 1st mark after the half and the slow speed fan still didn't come om Sad
relays changed
resistor changed
wiring repaired
anyone know what else could be stopping the fan from coming on
cheers
J
Lecktorious
PostPosted: Mon Jul 08, 2013 6:18 pm Up
Trade Rating: +59
Have you checked the multiplug on the wiring loom for corrosion?
'98 Nile Blue 306 GTi 6
weejoe86
PostPosted: Mon Jul 08, 2013 6:21 pm Up
where bouts is that? it was at a garage to get the wiring at the relays repaired
weejoe86
PostPosted: Tue Jul 09, 2013 9:08 am Up
have had a look there is no multi plug that I can see. it is an 03 2ltr hdi multiplexed with air con.
DREWDEN
PostPosted: Tue Jul 09, 2013 9:16 am Up
The multiplug is at the bottom of the radiator, and connects to the resistor.
Need to take the bumper off, as its very awkward to get to.
206 2ltr Hdi glx 53 plate
PostPosted: Tue Jul 09, 2013 9:17 am Up
relays changed
resistor changed
wiring repaired
cheers
J
ECU..
weejoe86
PostPosted: Tue Jul 09, 2013 9:19 am Up
if its that part then it has been checked when the resistor was changed. There is no corrosion of the wires there
PostPosted: Tue Jul 09, 2013 9:22 am Up
Does the high speed work then?
weejoe86
PostPosted: Tue Jul 09, 2013 9:23 am Up
I did t let it get hot enough. the fan works as the garage tested it before repairing the wiring at the relay
PostPosted: Tue Jul 09, 2013 9:25 am Up
I would make sure the high speed mode works, the garage should have tested both speeds by switching them on with PP2000 before giving back to the customer (that would be you).
DREWDEN
PostPosted: Tue Jul 09, 2013 9:42 am Up
I would just check and make sure he hasn't just cut the plug off, and joined the wires together.
Thats the case with mine at the moment.
My fan wasn't working, so the electrician just made the high speed fan work.
My job pretty soon, take bumper off, fit a new resister, and put the plug back on.
Did it this way to keep costs down.
