Latest: heikkisj
Overall: 17126
Online Now [51]:
Visitors: 50
Today: 4199
Total: 100313624
Forums › The Car › 206 Problems › Rattle at low speeds
Matthews206
PostPosted: Fri Jul 05, 2013 1:46 pm Up
Hi guys,
Just after a bit of help/advice...
I've noticed a metallic rattle coming from what sounds like the engine bay when I am driving a low speeds, most noticeable if I am in a gear slightly higher than I should be.
Has anyone ever had/heard of anything similar?
Chris
Silver LX Standard so far.......
Tolkienfan001
PostPosted: Fri Jul 05, 2013 1:59 pm Up
Trade Rating: +13
Ecu rattling? Coolant bottle? Heat shield? Get under the car and bonnet and start knocking and shaking things.
2005 1.4 16v Sport
Check out my 206 here!
frenchfrog40
PostPosted: Fri Jul 05, 2013 6:45 pm Up
mines done this since i got it, just over a year ago. to be honest i haven't actually tried to find out what it is yet. may do soon.
Iv had:
eddie206
PostPosted: Sat Jul 06, 2013 6:37 am Up
Could be rust fragments in the front pipe area of the exhaust..
tommyb32
PostPosted: Fri Jul 19, 2013 5:54 am Up
99.9% its going to be the heat shield they are prone to this! i have it on mine and it drives me nuts should sort it tbh lol
PostPosted: Fri Jul 19, 2013 8:28 am Up
Broken ABS ring on the driveshaft?
Simon2710
PostPosted: Fri Jul 19, 2013 10:36 am Up
Drop links? Only really notice these over rough patches of road.....
Simon
peugeotgti
PostPosted: Sat Jul 20, 2013 7:47 am Up
See thread.."Curious Rattling" for same advice..
Matthews206
PostPosted: Sat Aug 24, 2013 11:22 am Up
I have solved the problem now thanks to an oil leak of all things!
I found my gearbox was dripping oil and subsequently found the bolt on the gearbox were loose! No idea how this happened though...
Thanks for the help though
