Posted: Sun Jul 07, 2013 5:31 pm |
Do they do anything much on a 1.4i?
Even if a small amount?
Opinions would be appreciated as I'm slowly turning into chav, possibly due to this place.
'Even removed the wheel-trims now from the steelies and I think it's brilliant.
Thanks.
Posted: Sun Jul 07, 2013 6:33 pm |
I bought one for my 1.1 still havnt fitted it tough as it requires cutting the metal work undder the air vents on the bonnet, i think its more cosmetic with a 206 tough but every little helps
Posted: Sun Jul 07, 2013 8:42 pm |
V9977 wrote: |
Even if a small amount? |
No.
Posted: Mon Jul 08, 2013 3:18 am |
E5GDM wrote: |
V9977 wrote: |
No. |
Posted: Mon Jul 08, 2013 3:48 am |
Purely cosmetic and look only, yet I do have one fitted on mine
Posted: Mon Jul 08, 2013 6:27 am |
I'd love a brace fitted to welded in mounts...
Posted: Mon Jul 08, 2013 1:49 pm |
ill be getting a cage made up with strut support and cambered
Posted: Tue Jul 09, 2013 1:37 am |
Many thanks everyone, I'm OK again now..
