Latest: Mr-Koekwaus
Overall: 17125
Online Now [146]:
Visitors: 145
Today: 70932
Total: 99901465
Forums › The Car › 206 Problems › 206 1.9d 2002 plexed horn not working
fozzybear
PostPosted: Mon Jul 08, 2013 12:25 pm Up
Hi Got a problem with my 206 1.9d 2002 plexed horn not working. took horn of and tested with a battery and two wires works ok, next tested wires 250 and mc11k from connector get 12v when horn pressed on steering wheel and can also hear relay clicking from bm34 fusebox. any ideas greatly appreciated
cheers
Andy
PostPosted: Mon Jul 08, 2013 12:35 pm Up
Double check the connector plug, you may have 12 volts there BUT there may not be enough current passing through to sound the horn.
Tolkienfan001
PostPosted: Mon Jul 08, 2013 12:38 pm Up
Trade Rating: +13
I had this same issue. The wires to the horn and connector were faulty and corroded. I cut the wires back and soldered new wires and terminals. Works fine now.
2005 1.4 16v Sport
Check out my 206 here!
fozzybear
PostPosted: Mon Jul 08, 2013 12:49 pm Up
Thankyou for the quick response will use connector cleaner hopefully this will work strange one on me but hey anything possible. thought I was going mad... if not will change connector. Cheers Very Happy
fozzybear
PostPosted: Sun Aug 25, 2013 3:31 pm Up
Hi,
Just an update was the connector plug that was faulty on earth side, amazing changed connector and hey ho worked. typical french workmanship considering i work in france ... Laughing thankyou
fozzybear
PostPosted: Mon Aug 26, 2013 1:14 pm Up
just for information Peugeot here in france wanted 40.00 euros yes 40.00 euros just for the connector kit. got a replacement from breakers yard.
PostPosted: Mon Aug 26, 2013 1:49 pm Up
The connectors are about £3 new on Ebay.
