Latest: DanDan17
Overall: 17128
Online Now [72]:
Visitors: 71
Today: 20033
Total: 100418203
Forums › The Car › 206 Talk › Peugeot Planet?
Peugeot Planet?
Go to page 1, 2, 3  Next
buseng
PostPosted: Sat Jul 13, 2013 11:02 am Up
I have seen this on Ebay.
www.ebay.co.uk/itm/ACT...4610fb61d6
Can anyone confirm if this is the PP2000 kit or equivalent where you can activate various BSI settings etc.?
I realise you need a laptop as well.
PostPosted: Sat Jul 13, 2013 11:38 am Up
I notice from one picture that the sticker that hides 2 of the screws on the interface is damaged, looks like this has been apart at some point Wink
PostPosted: Sat Jul 13, 2013 11:44 am Up
I agree! What He Said ,but yes that is the PP2000
PostPosted: Sat Jul 13, 2013 12:32 pm Up
To me it looks like the clone interface. You can buy them as cheap new.
buseng
PostPosted: Sat Aug 03, 2013 3:11 pm Up
OK, I have bought a PP2000 kit. I have installed it on a XP laptop & all seems to be ok including the interface drivers.
However, I connected it to my 2005 206 mux, put in all the right details. Build number, selected mux version etc, but it does not do the most important thing. Find or read the engine ecu!
It finds the vin number & all the other ecu's doing a global search but on the engine ecu it says "ENGINE ECU-PP2000-UNKNOWN REFERENCE" & "ECU BEING REFERENCED" then "PRESENCE OF FAULTS". When click on it or select ok, it just goes back to the menu page.
Basically it knows there are fault codes (as expected) but cannot read or retrieve them, ie unable to access the engine ecu for some reason which defeats the whole object of it.
Any thoughts please?
PostPosted: Sat Aug 03, 2013 3:26 pm Up
Have you selected the right ECU? I cant remember how the process works but I have to select my ECU in PP.
Leegsi
PostPosted: Sat Aug 03, 2013 3:47 pm Up
I need mine installed.
If your local you could instal it for me and try my new interface.
buseng
PostPosted: Sat Aug 03, 2013 4:08 pm Up
I thought it identified it automatically. It finds all the other ecu's, airbag, abs, dash, mfd, radio, com2000 etc. .
Where do you find the engine ecu details?
buseng
PostPosted: Sat Aug 03, 2013 4:09 pm Up
No, I live in Reading, Berks.
buseng
PostPosted: Tue Aug 13, 2013 5:49 am Up
A bit of an update on this. Have updated the interface firmware from 4.2.2 to 4.3.0. Also installed the latest? interface drivers (2010).
Now running Diagbox 7.01. This is what I now get regarding the engine ecu.
Peugeot Planet 2000 13/08/2013 10:52:04
Please inform the technical assistance platform by email Diag specifying: control unit identification numbers( ECU identification label) .
In spite of this non-recognition of the ECU, do you wish to continue the diagnostics procedure?.
Peugeot Planet 2000 13/08/2013 10:55:20
Incorrect matching of the ECU (incorrect engine, system or vehicle).
Fit a correct ECU.
Does this mean my engine ecu has been changed to a non standard one in the past?
PostPosted: Tue Aug 13, 2013 10:19 am Up
How did you update them all. Don't use diagbox, only pp2000
buseng
PostPosted: Tue Aug 13, 2013 11:09 am Up
Using the discs supplied with the interface.
I did use PP2000 originally as stated above, but still did not identify the engine ecu. Just ecu being referenced.
The comments above showed up only when using Diagbox.
It knows the ecu is there & that there are faults present, but cannot go any further.
PostPosted: Tue Aug 13, 2013 12:54 pm Up
Diagbox isnt needed for a 206.
buseng
PostPosted: Tue Aug 13, 2013 1:09 pm Up
I only tried it because as stated PP2000 did not recognise my engine ecu. I thought updating the firmware/drivers/programme might help.
Still wondering if the highlighted messages mean my engine ecu is non standard.
PostPosted: Tue Aug 13, 2013 3:54 pm Up
Take the ECu out and check the codes underneath, highly unlikely its been swapped.
Page 1 of 3
