Hi,
It is MOT time soon so just have a question about some work I need doing.The front suspension struts need replacing does anyone know how much roughly this should be for an independent garage? Also I think I need a clutch, if I'm in 4th/5th gear the car overrevs but does seem to pick up speed still? I've tried having car stationary, sticking in 5th gear and lifting clutch alone and stalls normally. I do know I need a new air instake pipe as might be a small hole where the bracket is next to fusebox. How much would clutch replacement be if that is what it is?
