Latest: lio94
Overall: 17181
Online Now [144]:
Visitors: 143
Today: 22490
Total: 140499698
Forums › The Car › Request a how-to › how to take of drivers door
Forum IndexRequest a how-to
marshy206
PostPosted: Sun Jul 21, 2013 8:45 am Reply with quote Up
Hi i need to take my drivers door of is it easy to do and how do you do it
pug206lx
PostPosted: Sun Jul 21, 2013 6:57 pm Reply with quote Up
the way that I did it is to remove the wing, which gives access to the torx bolts behind. The whole hinge comes with it then. You need to disconnect the wiring and the torx bolt on the check strap also. There may be an easier way to do it, but this is how i did it.
PostPosted: Mon Jul 22, 2013 5:18 am Reply with quote Up
Unscrew the check strap, disconnect the wiring harness. Have someone support the door and remove the hinge pins.
  Quick Reply
Username:
Message:
Quote the last message
