Latest: DanDan17
Overall: 17128
Online Now [57]:
Visitors: 56
Today: 45277
Total: 100472936
Forums › The Car › 206 Talk › TU5JP4 1.6 16V Head with 106 gti cams?
Adam2061994
PostPosted: Tue Jul 23, 2013 7:45 am Up
just wondering guys, seen a few topics around that the 206 1.6 xsi TU5JP4 engine is a very restricted engine, and there's a few cheapish ways round it to get a bit of power by using things such as 106 gti cams within the xsi head, they say the cam is a lot wilder throughout the rpm and they think the valves are very big (3mm more) than the 106 gti so it would make sense to use the best from both cars, that way you may gain a little more torque lower down in the rpm as the xsi doesn't have a lot of torque at all low down! also heard changing the manifold to a 4-2-1 stainless steel as the standard one is only cast iron and very restrictive!, what inlets could i swap to gain a little more power and would anything else need swapping, im looking for around 150-160bhp, any ideas or setups that would help can you let me know, and how hard are they to do Smile thanks in advance
206 1.6 owner
Big_Rich180
PostPosted: Tue Jul 23, 2013 7:49 am Up
I thought there was a clearance issue with the pistons and valves when putting 106gti cams into the Xsi engine, I stand to be corrected though.
Adam2061994
PostPosted: Tue Jul 23, 2013 7:53 am Up
im not too sure, i heard a few things that the 106 gti cams have been put in, using the lifters and springs out of the 106 too, the setup i had found was, 106 gti cams with springs and lifters and put into the 206 xsi head, get a 4-2-1 stainless steel manifold, and then use the c2 VTs inlet and injectors as a straight swap as they are both electric throttle, and then with a forced induction and a map, he was hitting around 160bhp, but i would like to know more about it Smile
206 1.6 owner
Big_Rich180
PostPosted: Tue Jul 23, 2013 7:55 am Up
I thought 106 gti Pistons had to be used too as they had more of a cut out at the top for the valves..as I say though I could be wrong, it was a long time ago I was looking into this stuff and my brain tends to be a bit mushy now days.
It's probably worth checking the 106 GTi forum too.
Adam2061994
PostPosted: Tue Jul 23, 2013 7:57 am Up
well il do some more research as i would like to know more about this! thanks for your help
206 1.6 owner
PostPosted: Tue Jul 23, 2013 8:53 am Up
The best combination of that engine is the 106 GTi bottom end with the C2 VTs head and inlet but use the 106 GTi cams.
Big_Rich180
PostPosted: Tue Jul 23, 2013 9:05 am Up
Thats probably what I was trying to get at Laughing
lukepug19
PostPosted: Tue Jul 23, 2013 10:58 am Up
when I last enquied about this at pug1off they said you can do it but would need to use the lifters and pulleys to do it
234re
Adam2061994
PostPosted: Tue Jul 23, 2013 11:57 am Up
cant i just use the 206 xsi head arent they the same?
206 1.6 owner
Adam2061994
PostPosted: Tue Jul 23, 2013 12:00 pm Up
thanks bro Smile
206 1.6 owner
lukepug19
PostPosted: Tue Jul 23, 2013 1:07 pm Up
234re
PostPosted: Tue Jul 23, 2013 3:02 pm Up
It's already been said but yes you can, but you may as well use the GTI springs and lifters (JP4s aren't as strong).
You won't need pulleys, even if it did alter the timing the standard ones are adjustable.
I doubt it's worth the hassle to do, but if you are building an engine from scratch it's definitely the way to do it.
You won't see more than 150bhp without throttle bodies or turbo though.
