Posted: Thu Jul 25, 2013 6:30 pm |
Hello everyone, I've had my car for just over a year ( worse car ever, can't afford a new one ) I've always wanted to ask do I have the wrong gearbox? I've got a 1.6 16v xsi , I'll tell you my gear ratios, 1st no idea, 2nd 50mph hits the limiter, 3rd just hits 70 and hitting the limiter, 4th 90 and hitting the limiter, 5th no idea.
Seems my ratios are low, if I'm driving along going 50, all I hear is engine noise like it needs 6th, I'm getting sick of this, its so annoying and sounds like my engine is going to blow.
Any help or info would be great.
And just to clear something this was tested on OUR private road, and I know its bad hitting the limiter but I'm fed up and I had to find out the ratio speed.
Posted: Thu Jul 25, 2013 9:02 pm |
Mines about that mate 1.6 8v xs same gearboxes I think
Posted: Thu Jul 25, 2013 9:57 pm |
what rpm is the engine at when cruising at 50?
Posted: Fri Jul 26, 2013 2:12 am |
Around 3200 rpm
Posted: Fri Jul 26, 2013 4:57 am |
I put mine in 5th at 50mph for around 2500rpm which is the quietest my engine is. That sounds like you are still in 3rd or 4th?
Posted: Fri Jul 26, 2013 6:10 am |
Sounds normal.
Posted: Fri Jul 26, 2013 11:12 am |
What are the revs in 2nd doing 50
What are the revs in 5th doing 50
| 206 2ltr Hdi glx 53 plate | |
Posted: Sat Jul 27, 2013 3:24 am |
Sounds fine. But I can sort of gather why it hasnt been a good car to own, if your hitting the limiter in fourth
| Team Impossible Possible
Posted: Sun Jul 28, 2013 5:24 pm |
Addaz wrote: |
Sounds fine. But I can sort of gather why it hasnt been a good car to own, if your hitting the limiter in fourth |
I was only hitting the limiter to find the ratios, I'm no mechanic and I didn't know how else to find out the ratios, I've always thought the previous owner had modified or put the incorrect gearbox in. If you read my whole post which states I wanted to find out the gear ratios hence why I was hitting the limiter you wouldn't be assuming why the car hasn't been good to me, I can only tell you to learn to read.
Many Thanks
