Forums › The Car › 206 Problems › Is my pug in a bad way? |
Posted: Sun Jul 28, 2013 7:21 pm |
Hi all
Recently my Pug 206gti has been running a bit rough to say the least. I started it this morning which took 3 attempts and when it finally did start it didn't want to idle for that long.
Once the car warms up it runs ok and every now and then it stalls at idle which is not suitable if you're at an intersection.
One more thing!
When I accelerate I can hear a rattling noise coming from the engine. This only happens under acceleration and not when revving.
Posted: Sun Jul 28, 2013 11:42 pm |
try to clean the stepper motor (Idle Control Valve),and clean the throttle body itself,and see how things go.
Posted: Mon Jul 29, 2013 2:51 pm |
If it will run with the throttle applied it's a safe bet it's the idle control valve.
