Posted: Tue Jul 30, 2013 10:28 am |
Hi guys,
A few weeks back, a clicking/knocking sound started at the right rear underneath my 206 1.1L. It only started when going over speed ramps and deep potholes on the road. Since then though, it has become more frequent and is knocking more often.
I thought it may be that the spare wheel was loose so I tightened it up. The knocking is still there so I don't think it is that anyway, but if I move it enough, there is a similar sound coming off it.
Any ideas what this may be?
| 3-Door 206 1.1L LX in Metallic Silver 2003 REG  | |
Posted: Tue Jul 30, 2013 10:40 am |
do either of the back wheels have play in them?
Ie jack up the car and see if you can move the wheels back and forward to see if there is any play with the bearings.
Posted: Tue Jul 30, 2013 10:56 am |
Cheers for replying ianlovatt..
I can't jack it up at the moment, but if there is or isnt wheel play, what do you think it might be?
I've been doing a bit of research and found it could be either wheel bearings need replacing or the rear axle worn?
