Posted: Sun Aug 04, 2013 7:31 pm |
Hi
Where exactly do i T-piece into the vacuum pipes to fit a boost controller and a boost gauge?
to the back of the engine there is an actuator going to a soleniod, the pipe that joins them, would that be an appropriate place ?
Cheers
Posted: Mon Aug 05, 2013 12:56 am |
Manual boost controllers are the devils work. And I strongly recommend avoiding the temptation.
For the boost pickup for a gauge. Use some where close too or off the inlet manifold, or worst case just off the boost pipes after intercooling
| Team Impossible Possible
Posted: Mon Aug 05, 2013 6:00 am |
So how do you control the boost if you don't use a manual boost controller ?
Posted: Mon Aug 05, 2013 1:03 pm |
seanbrown121 wrote: |
So how do you control the boost if you don't use a manual boost controller ? |
Electronic boost solenoid, that when you remap the car the pressure is increased
