Posted: Wed Aug 07, 2013 5:14 pm |
So my lovely 206 has died, cambelt came off and destroyed the engine.
Its at my local garage, it was going to have a new(used) engine put in, but they said they were mis quoted and that was too much.
It is now having an engine rebuild for £1500, BUT the garage is saying its waiting on two fundamental parts that can only be got from Peugeot... They then said, Peugeot has a back order of parts so could take and unknown amount of time.
Has anyone else heard of this? Its been two weeks now and I'm dying for my car back...
| 2004 Black 206, 1.6 HDI GTI.
My Old Pug New one to come! | |
Posted: Wed Aug 07, 2013 5:27 pm |
Trade Rating: +59
Find out what parts it is and approach Peugeot direct. Never had to wait more than 10 days for parts, including back order from France.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Wed Aug 07, 2013 5:33 pm |
Good idea, I will find out tomorrow, and post back to you guys! Thanks
Posted: Thu Aug 08, 2013 12:10 am |
EBay spares & repairs, let some other mug have the problem.
FYI: they stopped production of this engine a few years back, its now obsolete.
Posted: Thu Aug 08, 2013 2:34 am |
Should have had it serviced.
Just buy a complete engine and send it to the garage and just get them to fit it. Would be cheaper than £1500. Last time we had a engine fitted it cost £400
Posted: Thu Aug 08, 2013 6:34 am |
MrBSI wrote: |
FYI: they stopped production of this engine a few years back, its now obsolete. |
So how does that differ to the 1.6 HDI engine available now?
Posted: Thu Aug 08, 2013 7:54 am |
I would just replace the whole engine. Unless a specialist rebuilder was doing the work, I wouldn't trust the engine again.
www.ebay.co.uk/itm/PEU...232d0ea9c9
Cheapest on Ebay.
Posted: Thu Aug 08, 2013 9:28 am |
iainlovatt wrote: |
Just buy a complete engine and send it to the garage and just get them to fit it. Would be cheaper than £1500. Last time we had a engine fitted it cost £400 |
,Well it's always to replace the whole engine instead of rebuilding it,because engines done by the factory is much better than any garage,and the cost of rebuild is very expensive I say,don't worth that,so get a second hand engine or maybe a brand new one if you are lucky,and got it serviced :),new cam belt,water bump,....etc.
Posted: Thu Aug 08, 2013 9:32 am |
Edward wrote: |
MrBSI wrote: |
So how does that differ to the 1.6 HDI engine available now? |
16 valve version of DV6 killed of in 2011.
Current version of DV6 is only an 8 valve unit.
Posted: Thu Aug 08, 2013 11:02 am |
5 quid says it broke the followers and thats it
Slap a new belt on and see, shouldnt cost more than 200 to fix if you do it yourself
| Team Impossible Possible
Posted: Thu Aug 08, 2013 1:33 pm |
Addaz wrote: |
Slap a new belt on and see, shouldnt cost more than 200 to fix if you do it yourself |
+5
DIY rebuild and you're laughing.
Posted: Thu Aug 08, 2013 4:04 pm |
1500 is more than the value of the car mate, must be mad
Posted: Fri Aug 09, 2013 6:45 am |
my cam belt went, only cost 400 quid to sort.
8 new valves, new cam belt kit, cylinder head skimmed, new gasket, oil filter, fresh oil and new engine coolant...
unless it did more damage than this, 1500 quid is a rip off
oh and i did it doing 60 mph
