Online Now [918]:
Visitors: 918
Today: 214267
Total: 151696040
Forums › The Car › 206 Problems › Leak from washer bottle
DCFC734
PostPosted: Fri Aug 09, 2013 9:34 am Up
Just noticed my windscreen washer bottle has a leak coming from what appears to be where the 2 pieces of the washer bottle join together. Im hoping its the top part of the bottle eg the part you can remove but no idea what the name of the part is to search ebay and what not. Anyone able to help.
Thanks for your help.
Just come across a thread from a few years ago mentioning a diy job or replace the bottle itself. Think ill find out if its the whole bottle that needs replacing.
206 owner
PostPosted: Fri Aug 09, 2013 9:43 am Up
It will be the O ring seal, common issue.
Take the filling tube of & go down the plumbing supplies shop & match up a replacement O ring.
DCFC734
PostPosted: Fri Aug 09, 2013 9:47 am Up
Thanks, that was something else that was mentioned.
Thanks, looks like a trip to a plumbing supplies is needed.
206 owner
PostPosted: Fri Aug 09, 2013 2:06 pm Up
What He Said
tommyb32
PostPosted: Sat Aug 10, 2013 8:23 am Up
What He Said happens on every 206 iv'e had lol
PostPosted: Sat Aug 10, 2013 9:53 am Up
Also Peugeot don't sell just the O ring on it's own, it only comes with the filling tube for around £11.
I just went in the box of new O ring's at work & found one that fitted Laughing
DCFC734
PostPosted: Wed Aug 14, 2013 11:43 am Up
I looked at the O ring and it actually looks fine or is it a bit deceiving in the way it looks ?
206 owner
