Online Now [50]:
Visitors: 49
Today: 1783
Total: 117465369
Forums › The Car › 206 Talk › stadnalone ecu still need using bsi
heyziq
PostPosted: Thu Aug 08, 2013 12:23 am Up
like titlle above i wonder if standalone ecu still need using bsi, as i know bsi help control signal, fuel pump bla2, i there any way to get rid it the bsi..?
mine gti preplex
heyziq.com
PostPosted: Thu Aug 08, 2013 6:35 am Up
You need all the original wiring and ECU parts to run the clocks etc.
imjeeves
PostPosted: Thu Aug 08, 2013 5:22 pm Up
the ecu will only run the engine aspects you need the orginal ecu etc to run the clocks and internal swtiches etc
PostPosted: Fri Aug 09, 2013 1:50 am Up
Spike has had his original ECU removed...so it must be possible to remove it...not sure how though.
imjeeves
PostPosted: Fri Aug 09, 2013 2:08 am Up
You would need to wire all your switches etc separate into a fuse box. That's what I've done anywat
heyziq
PostPosted: Sat Aug 10, 2013 1:23 am Up
thats means the standalone will become piggyback to the original ecu??
heyziq.com
heyziq
PostPosted: Sat Aug 10, 2013 1:41 am Up
oh mate u take out your ecu, then each switch will plug in to new custom look? look like mental job for me
heyziq.com
imjeeves
PostPosted: Sat Aug 10, 2013 2:42 am Up
It is a huge job I would not advise unless you really know what u are doing!
PostPosted: Sat Aug 10, 2013 9:26 am Up
You could probably get the engine running without it as it won't require the standing matching but you would have to do everything else custom to be actually able to drive it.
heyziq
PostPosted: Sat Aug 10, 2013 9:45 am Up
yup true, in that case i think im going to use the piggyback ecu,
cant stand ecu+bsi problem on my car
heyziq.com
