Forums › The Car › 206 Talk › Dipsticks?! |
Posted: Sun Aug 11, 2013 12:09 pm |
Are they all the same part number across the range?
Need one for my GTi 138.
Posted: Sun Aug 11, 2013 12:45 pm |
I'm sure I did a 'how to' on here once...complete with part number for the new GTi dipstick that stays in the tube!
Posted: Sun Aug 11, 2013 1:11 pm |
Ive got the new part number (1174 e1). Some how ive lost mine giving the engine an overhaul!
I'll pm you about something if you don't mind Edward.
Posted: Sun Aug 11, 2013 6:21 pm |
£10.60
