Posted: Wed Aug 14, 2013 2:33 pm |
do you leave the top thin pipe off the radiator when filling? also is there a bleed valve any where?
Posted: Wed Aug 14, 2013 2:50 pm |
No you use the two bleed nipples on the rear heater pipe and thermostat housing. The one on the housing is a allen key I think
| Team Impossible Possible
Posted: Wed Aug 14, 2013 2:57 pm |
have you got any pictures of the where abouts?
Posted: Wed Aug 14, 2013 3:02 pm |
Leave all pipes connected and fill system. There should be a bleed screw either on the thermostat or the pipe leading into the hearter matrix at the back of the engine bay. maybe both.
Posted: Wed Aug 14, 2013 3:04 pm |
Posted: Wed Aug 14, 2013 4:39 pm |
As me and addaz said, Timmons pics show the points. It's the same on all 206s/cars generally.
