Posted: Thu Aug 15, 2013 8:30 am |
hi.
hope someone can help. I am trying to remove rear seats. On the 2/3 backrest when undoing last bolt. it has come halfway out and now all it does is just spin. Any advice on how to remove it?
Posted: Thu Aug 15, 2013 10:20 am |
They bolt through the floor so more than likely rust has eaten away the threads. Apply force upwards while turning, I'll pop out.
Posted: Thu Aug 15, 2013 2:54 pm |
I have tried wedging it with a screwdriver and claw end of hammer. But makes no difference it just keeps spinning. I have got every other bolt out apart from this one. Its the one at the back of the seat inn the boot.
Posted: Fri Aug 16, 2013 9:43 am |
You could cut the top off, cut a slot across the stub and screw it out from the bottom. Then get a new one from scrappers.
Posted: Fri Aug 16, 2013 11:37 am |
If you screw it back in can you get to the rusted part of the bolt from below and cut that off and then undo the bolt as normal from above?
