Online Now [238]:
Visitors: 237
Today: 74646
Total: 142585065
Forums › The Car › 206 Problems › Electric Windows/Mirrors In-op!
gordr
PostPosted: Thu Aug 15, 2013 12:00 pm Up
Hi Guys
Iv got a 05 Plate 206 GTi, neither the front windows or electric mirrors work.
Any suggestions?
Gordon
Tolkienfan001
PostPosted: Thu Aug 15, 2013 12:09 pm Up
Trade Rating: +13
Fuse?
Do anything different or change anything before the stopped working?
2005 1.4 16v Sport
Check out my 206 here!
gordr
PostPosted: Thu Aug 15, 2013 12:14 pm Up
Had a quick look at the fuses, couldnt see any that look blown, although unsure which number it is as iv not got an owners manual.
And no, iv only recently bought the car and they were not working.
gordr
PostPosted: Thu Aug 15, 2013 12:19 pm Up
Also tried fitting a window switch out of a different 206, (only had window switch & not mirror controls) but did not make any difference.
iainlovatt
PostPosted: Thu Aug 15, 2013 12:52 pm Up
Does the switch light up either on mirror knob or window buttons?
(My Garage)
PostPosted: Thu Aug 15, 2013 12:56 pm Up
Fuse 12 in the passenger compartment fusebox. Should be a 30 amp.
Be careful fitting another switch as there are issues when trying to mix switches that have the auto function for the drivers window and those that don't.
Pop the switch out and make sure it's connected.
Tolkienfan001
PostPosted: Thu Aug 15, 2013 1:00 pm Up
Trade Rating: +13
What He Said
I popped a fuse changing the switch Smile
2005 1.4 16v Sport
gordr
PostPosted: Sat Aug 17, 2013 9:52 am Up
UPDATE:
Checked fuse 12 (30amp) and its all ok. Also tried a correct switch with mirror adj and auto rocker. Still nothing!
Also the switch does not illuminate.
Any suggestions?
PostPosted: Sat Aug 17, 2013 10:08 am Up
It hasn't got any power going to it.
Your either missing the + or earth in to the switch.
gordr
PostPosted: Sat Aug 17, 2013 10:32 am Up
Is it likely to be linked through the body control module? Or a broken wire issue?
PostPosted: Sat Aug 17, 2013 10:35 am Up
Get the multimeter out & start testing, start at the connector plug & work back towards the BSI unit.
You did check the fuse with a multimeter & not just looked at it?
gordr
PostPosted: Sat Aug 17, 2013 10:50 am Up
There is a live to both sides of the fuse. There is also a switch live to the switch.
