Latest: tc.206
Overall: 17147
Online Now [51]:
Visitors: 50
Today: 1915
Total: 116544415
Forums › The Car › 206 Problems › will a 2002 02reg loom fit a 2000 X reg
john206gti
PostPosted: Mon Aug 19, 2013 2:19 pm Up
As above realy.
2000 is a 1.4 8v
2002 is a 1.1 8v
Both are 3plug ecu
Grey plug on coil pack.
Basically ive got an intermitant misfire (p0200)
Changed coilpack. Fitted bosch plugs. Ecu temp sensor and still there.
Going to test Injectors tomorrow and was going to change the loom over
While im there as the earth onto coilpack looks a bit rough.
Ive got the 2002 which im breaking so can rob loom off that
Any over help on what you guys think it could be would be great.
Cheers
2001 moonstone gti, gt bumpers, gen2 k&n induction kit, lightened flywheel, lowered 35mm,
PostPosted: Mon Aug 19, 2013 2:26 pm Up
Unless the 2002 one is pre plex, no
john206gti
PostPosted: Mon Aug 19, 2013 2:33 pm Up
2002 is multiplexed so no then.
Forgot to say if I remove battery for a bit and reconnect it it runs fine for about 5mins then
Eml light come back on goes back to misfire.
Would a bsi reset bennefit?
Leegsi
PostPosted: Mon Aug 19, 2013 3:26 pm Up
As P0200 is normally injector problem I would try a known good injector first
PostPosted: Mon Aug 19, 2013 4:38 pm Up
Checking and comparing plug colours may even highlight which injector is giving the problem.
Gunsons colour tune even gives you a window into the combustion chamber!
john206gti
PostPosted: Tue Aug 20, 2013 1:53 am Up
Will the injectors from the 2002 fit the 2000?
PostPosted: Tue Aug 20, 2013 2:02 am Up
I've still got one in the cupboard somewhere, great bit of kit when I use to fiddle with carbs all those years ago.
PostPosted: Tue Aug 20, 2013 2:04 am Up
Possibly IF there the same spec, I think there are at least 2 or 3 different types on the smaller TU lumps.
PostPosted: Tue Aug 20, 2013 5:08 am Up
I still fiddle with carbs fitted to my 1984 Alfetta GTV 2.0l track car and my 1994 1200 Triumph Trophy. Very little is as rewarding as getting a set of Twin 40s balanced and a perfect idle and pickup.
Another trick I have learnt is to use one of those IR temperature sensors. If you point it at each branch of an exhaust any significant temperature difference will highlight a problem with the appropriate cylinder. Another simple diagnosis tool.
PostPosted: Tue Aug 20, 2013 9:34 am Up
I have a Draper one in my toolbox, also got temp function on my Fluke meter with a probe, both come in handy diagnosing brake coil issues on forklifts.
The brake coil is meant to have a set resistance at a set temperature.
