Forums › The Car › 206 Problems › rear axle |
Posted: Sun Sep 01, 2013 7:34 am |
hi guys, i recently bought myself a gti 180. and the rear RH wheel is leaning into the arch a fair bit. i was wondering if anyone with experience of this would be able to give some input as to whether its best to get a new axle or if the repair kit that sells on ebay is any good?
Posted: Sun Sep 01, 2013 10:25 am |
New axle. By the time the wheel is leaning everything else is trashed and it will take more than a repair kit to effect permanent cure.
Posted: Sun Sep 01, 2013 1:33 pm |
ok thanks for that, very helpful. cause it would probably take the same amount of time to do the bearing as it would the axle. thanks again
