Latest: Mr-Koekwaus
Overall: 17125
Online Now [516]:
Visitors: 515
Today: 51532
Total: 99882088
Forums › The Car › 206 Problems › No acceleration
No acceleration
Aimon
PostPosted: Sun Aug 25, 2013 8:19 pm Up
My car is 206, 1100CC, Petrol has the following problems:
Fuel consumption is too high
At start, RPM may be too high (3000) and then decreases to (2000) OR it may vibrates between 3000 and 2000 OR it may be normal 2000 then 940
The engine may cut off during idle
During run, the car may vibrates
During RUN, acceleration may be lost and then it can be retained if I restart the engine
Check engin indicator may flashes and then no error is recorded when tested
Idle stepper motor was replaced with no use
Have you solution, Thanks in advance
PostPosted: Mon Aug 26, 2013 12:40 pm Up
Whats the manifold air pressure?
Sounds like you have an air leak in the inlet track
