Online Now [248]:
Visitors: 247
Today: 80225
Total: 142224354
Forums › The Car › 206 Talk › What can I do with my laptop on my pre-plex?
Jerakeen
PostPosted: Tue Aug 27, 2013 1:42 am Up
My GTI is a 1999 model so I know it doesn't have the CAN-BUS but does it still have OBDII and if so what can I do with it? Is there any advantage for me to get hold of one of the (rather expensive) interfaces to connect it up to my laptop?
PostPosted: Tue Aug 27, 2013 6:04 am Up
Question is what do you want to do with it?
You can do nearly everything essentially, it just means spending much more to get it all working.
PostPosted: Tue Aug 27, 2013 6:52 am Up
£35 will get you a diagnostic read that will bring back live data (coolant temp, rpm, throttle position etc)...what more do you want to see?
Jerakeen
PostPosted: Tue Aug 27, 2013 9:30 am Up
If it does fault codes as well that's probably enough. What should I be looking out for when buying the reader? There seem to be a wide range of things on Ebay from about a tenner up to several hundred.
PostPosted: Tue Aug 27, 2013 2:07 pm Up
I bought an Autel Maxiscan MS509 which is fine. Rated highly by Car Mechanics Magazine.
