Latest: DanDan17
Overall: 17128
Online Now [81]:
Visitors: 80
Today: 38298
Total: 100465959
Forums › The Car › 206 Talk › 206 GTi buyers guide - Practical Performance Car - Sept 2013
PostPosted: Fri Sep 06, 2013 1:11 pm Up
Not sure if anybody has spotted this...I'm sure it will be of no use to use at all. Not read it yet but will do later. I'll check it for inaccuracies!
PostPosted: Fri Sep 06, 2013 1:44 pm Up
Sounds like the guide is about 8 years to late Laughing
PostPosted: Fri Sep 06, 2013 3:35 pm Up
It's in there because prices are now sub £1k...
PostPosted: Sat Sep 07, 2013 3:59 am Up
Chavs will be buying them up to ruin even more now Laughing
Will be handy for other who go GTI bit's hunting in the scrapyards Whistle...
tsotd
PostPosted: Sat Sep 07, 2013 1:07 pm Up
does it say in big letters not to buy one? (i mean the gti not the 180)
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
PostPosted: Sat Sep 07, 2013 2:15 pm Up
It says don't go out of your way to buy a 180 instead of a 138!
PostPosted: Sat Sep 07, 2013 2:31 pm Up
Well after reading/doing a course on the architecture of the ew10js. I can safely say its nothing special at all.
Ew12 cylinder head, 4 branch and 180 inlet, and your 138 would fly!
PostPosted: Sat Sep 07, 2013 2:58 pm Up
Few mass production engines are that special. It's got a stronger bottom end than the 138 though.
PostPosted: Sat Sep 07, 2013 3:28 pm Up
Actually, its not. It has oil spray jets with slightly refined 138 pistons.
Nothing else
PostPosted: Sat Sep 07, 2013 3:32 pm Up
Rods are different.
Schumi
PostPosted: Sun Sep 08, 2013 4:43 am Up
Well well well. Same things still going here. Did you even have a change look inlet and exhuast ports of both engines cylinder head. Port is much more bigger but I'm not pointing that. Entire port shape different on both head. J4S (ES code on head) much much more better than regular J4 head (E0 code on head) Smile
With exatcly same mods J4S will be more powerful and more reliable due oil jets and balanced crankshaft for higher revs. Smile
Only thing I hate on both engine is oil pump. Its not good at high revs.
2005 206 RC RED
