Latest: Andyblue64
Overall: 17123
Online Now [67]:
Visitors: 66
Today: 55282
Total: 98326860
Forums › The Car › 206 Problems › new comms unit auto lights help
donnypaul81
PostPosted: Tue Sep 10, 2013 3:44 am Up
Hi everyone I fitted a new Delphi comms unit to my 206 2.0 hdi which cured the indicator problems I had only thing is I can't turn the auto lights off I've pressed the auto button in for over 4 seconds with the key turned to the first notch but it won't beep or any thing or show it turned off on the center display. I've done a bsi reset which at first the lights stayed off so decided to try with the lights on then turn them off and I'm back to them on all time. I did notice last night the auto lights did not make the clocks light up on the dash either but might do now I've done the bsi reset. I got the correct unit with matching part numbers as well. Any ideas why I can't turn them off ? Or have they come on because the sky is cloudy with no sun ?? Only thing is with having auto lights on and running at all times it burns bulbs out every other month and car is up for sale now as well so needs to be sorted tonight if possible as someo is coming to either part ex or buy the car. I have read that Citroen recalled some cars and vans which they also got stuck with the lights on all time which they had bypassed the auto light switch so have I ended up with 1 of these units as the manufacturer date stamp on it says 2003 ?? Any help will be thanked this afternoon. Oh and if there's a setting in Peugeot planet can someone let me know what to do as I know a young lad with this set up but unsure what to do only basic like clearing fault codes off.
PostPosted: Tue Sep 10, 2013 6:15 am Up
You can turn it off with pp2000. I think you need to hold the button on the indicator stalk with ignition on to disable auto lights. Although they should only light up at night, I doubt its that gloomy in the day at the moment!
There is also a procedure for setting there sensitivity, Google that.
mattymj
PostPosted: Tue Sep 10, 2013 6:27 am Up
I cant find anything on google about setting the sensitivity
donnypaul81
PostPosted: Wed Sep 11, 2013 10:15 am Up
Hi thanks for replying on this issue I have I asked the lad I know with the pp2000 about turning auto lights on and he said it sounds like it's got day time lights option turned as his also has this setting on his car activated which leaves his lights on all the time when car is started up as well as on a night time his clocks are not illuminated. So I will report back after he's had it on computer at weekend see if it's activated.
PostPosted: Wed Sep 11, 2013 1:16 pm Up
Can try, but I doubt changing the comm unit would change the bsi setting. What happens when you turn on the sidelights?
donnypaul81
PostPosted: Wed Sep 11, 2013 2:33 pm Up
Side lights turn on with the dash lit up and when I put all lights on every thing still works. See since owning the car I've always had this fault after 2 days of owning so don't know if the lights were on all time or not all I can remember is the indicators not working right n lights been messed up.
donnypaul81
PostPosted: Sun Sep 29, 2013 6:27 am Up
Had the car on pug planet yesterday and disabled the auto lights and also the auto wipers as well because they are crap and everything works as it should do apart from the obvious auto functions. Sadly the car is going too many problems with electronic equipment which are now all sorted but I will never win another French made car. First the r5gtt 6 grand in parts in 7 months the pug 306 dturbos I had same again electronic problems the saxo vtr electronic problems along with rear axle failures not once but twice and then there's this 206 so never again lol the French design good cars but can't build to last.
