Latest: lio94
Overall: 17181
Online Now [132]:
Visitors: 131
Today: 36959
Total: 141226626
Forums › Tuning, Modification & Legal › Project Cars › 206 GTi turbo NOW 205 GTi turbo
PostPosted: Sat Sep 14, 2013 6:07 am Up
Edward wrote:
They are different to normal engines. They use the BMW valvetronic system and VVT as well. So a normal standalone ECU wouldn't have the right outputs to control the engine.
The turbo engines VVT compared to the NA engines with VVL.
Both are s**te engines and should die out like the plague. Plus dont forget the petrol engines run direct HIGH pressure fuel systems as found normally on a diesel
That would be the most pain in the a**e engine to wire i can think of!
eddy_gti
PostPosted: Sun Sep 15, 2013 6:17 am Up
I went down to see jim yeaterday but the 180 manifold I bought wont be here till tuesday so there is not much that can be done for the time being although he does have 2 or 3 2.0l 8v turbo engines lying around. Quite tempted to just fit one of them for the time being while I build up the 16v gti engine and maybe get it done to a better standard with a full engine rebuild with low comp pistons, bit head work and a bigger turbo for more power. Just so many options!!!
Can anyone tell me how easy/hard it is to remove the dash from a 206?
eddy_gti
PostPosted: Mon Sep 16, 2013 9:39 am Up
Well i had a nice 10 hour night shift last night and got to bed around 9.30 only to have the postman banging on my door at 1pm this afternoon waking me up then i couldnt get bac to sleep! but i suppose i cant complain... untill i start work at 11pm again tonight. He brought me some shiny bits for the 206 B) The kits starting to build up bit by bit. Also digging around in my utility/parts room to find a braided brake like kit i bought last Christmas for my gti6 track car when i was planning on getting rid of the ABS. Might fit it to the 206 when i come to fit the turbo parts but then that would mean pulling the interior out as new brake lines would run inside the car with a compbrake bias valve. Anyway here is what turned up today and the brake lines i dug out.
eddy_gti
PostPosted: Thu Sep 19, 2013 12:54 pm Up
GTi180 manifold arrived today so next week i can make a start on the turbo manifold Very Happy Also came with it was a GTi180 engine cover... what doesnt fit at the minute, the engine lift hook is in the way whats not a problem and also is the throttle cable what shouldnt be there for much longer as i hopefuly plan to have a custom inlet fabricated for the turbo conversion.
Also my Bailey Dump valve arrived yesterday along with an adjustable fuel pressure reg.
Next:
Walbro 225 high pressure fuel pump
440cc OR 660cc injectors
Slim line fans
Ramair induction kit
Turbo oil feed
Braided fuel lines
Oil cooler
Air fuel ratio gauge
Think thats about it for the time being and then should hopefully have everything ready to fit and fingers crossed get running
heyziq
PostPosted: Fri Sep 20, 2013 1:37 am Up
tempting man! going to do this soon too. 406 8v ecu direct fit?
heyziq.com
eddy_gti
PostPosted: Fri Sep 20, 2013 2:24 am Up
No will need the loom modified to fit mate. Its not permanent, its just to get it up and running till I get an omex or a vems.
heyziq
PostPosted: Fri Sep 20, 2013 8:43 am Up
nice, don't forget share the wiring to mix with standard loom, I believe the 406 8V ECU need to be unlock?
Another thing, will you use standard internal or head spacer, like decompression plate or you will use forged piston and rod?
EW10 from 407 turbo in my country uses standard internal boosting 150Nm to 240Nm with boost 2.76psi only RON 95 , HP gain 40+ on wheel
heyziq.com
heyziq
PostPosted: Fri Sep 20, 2013 8:45 am Up
also still wondering how u modify gti 180 manifold to become turbo manifold???
heyziq.com
eddy_gti
PostPosted: Fri Sep 20, 2013 12:51 pm Up
Manifold is pretty easy to do. Mix a 180 manifold and a 306 gti6 manifold, there are a couple of different ways to do it.
internals will be standard with 2 head gaskets and a 1mm decomp plate what should drop me down to 8:1 compression. I dont plan to run any more than a bar of boost to start with, I will just see how things torn out then I can tweek it till I get the best from the engine.
photos will come if everything when I start Smile
heyziq
PostPosted: Fri Sep 20, 2013 1:13 pm Up
Sorry ask a lot, very interested like im the one running this project
the decompression plate also will be 1mm custom made + original peugeot metal gasket as far i understand,usually seing people buy from dp engineering
heyziq.com
PostPosted: Fri Sep 20, 2013 2:08 pm Up
2 head gaskets and a 1mm plate will c**k up the cam timing nicely. You'll need vernier pulleys too.
eddy_gti
PostPosted: Fri Sep 20, 2013 5:04 pm Up
I have been trying to find out info on the gti180 cam pullys as I hear they have VVT and would they work on my gti 138 cams?
other option is to see if I can find a thicker head gasket or fit 8v sri or 306 xsi pistons.
just sorted an oil cooler with thermostate sandwich plate
heyziq
PostPosted: Sat Sep 21, 2013 12:27 am Up
hmm year 99 206 did have adjustable pulley mate may use that one?
heyziq.com
PostPosted: Sat Sep 21, 2013 1:50 am Up
Just get some aftermarket pulleys.
eddy_gti
PostPosted: Sun Sep 22, 2013 8:27 am Up
Any one know the standard compression on the 138 engine?
Page 2 of 4
