Latest: flipflap
Overall: 17140
Online Now [255]:
Visitors: 254
Today: 71340
Total: 113871258
Forums › The Car › 206 Talk › Help with flickering
Aaronjames9
PostPosted: Mon Sep 09, 2013 4:40 pm Up
My red battery light keeps flickering and the clock does too when I open the car door when the keys are out, what could this be?
tRiCk
PostPosted: Mon Sep 09, 2013 4:46 pm Up
HMMM,, It could be a loose battery terminal if your lucky
Aaronjames9
PostPosted: Mon Sep 09, 2013 5:33 pm Up
What if it is not a lose battery terminal? It only started doing it today, the car starts and runs first time and runs smoothly
tRiCk
PostPosted: Mon Sep 09, 2013 6:07 pm Up
Strange one, it sound like a low battery voltage fault to me. I would have to look at it to know for sure.
Aaronjames9
PostPosted: Mon Sep 09, 2013 6:19 pm Up
So is it an easy fix or would I need to replace the battery?
rlees85
PostPosted: Wed Sep 25, 2013 3:07 am Up
Battery light is normally charging circuit related. Check terminals first as that's easiest, then I would (if you have a multimeter) check the voltage across the battery with the engine running... if its under 14v its probably your alternator.
