Latest: sparrowdclxvi
Overall: 17139
Online Now [127]:
Visitors: 126
Today: 36494
Total: 113236404
Forums › The Car › 206 Problems › 206 p0137 code after o2 change
neoluz
PostPosted: Mon Sep 23, 2013 9:20 am Up
Hi, i had mil light that came up for p0137 error, then i have changed catalytic and bank 1 2nd o2 sensor on my gti 180 06 plate. And now after appx. 100km i got the same error code again.
Anyone have any idea or have heard what could this be?
PostPosted: Mon Sep 23, 2013 1:53 pm Up
well since you changed your catalytic converter,and the second lambada sensor,then I must say you have a problem with the wiring,because this sensor should have a voltage reading,if it stays the same for more than 2 mins.then the MIL light will be on,so check your harness,and the voltage supply to that sensor.
PostPosted: Mon Sep 23, 2013 1:55 pm Up
here a link about it,and how to fix it,take a look:
Fault Code P0137
neoluz
PostPosted: Tue Sep 24, 2013 11:38 am Up
ok thanks, ill check that. it is just that mil does not come on after 2 mins... it comes on after ab 50-100km or so and just when i push it around 140-170km/h.
