Posted: Thu Oct 24, 2013 9:34 am |
Instructions at back of the can says put contents in warm engine then Rev in neutal at 2000rpm for no more than 15 mins.
Instead of executing this instruction can I do an alternative which is to drive around at 2000rpm for 15 mins? Or will this cause problems to the engine?
Posted: Thu Oct 24, 2013 10:21 am |
Trade Rating: +13
Why would you want to do something other than the instructions given?!?!
Posted: Thu Oct 24, 2013 11:22 am |
Tolkienfan001 wrote: |
Why would you want to do something other than the instructions given?!?! |
I could use the 15mins to drive to a garage for a oil change instead of arriving at garage and waiting another 15mins for flush.
Just want to know will it damage the engine if I do it my method?
Posted: Thu Oct 24, 2013 1:55 pm |
Just follow the advice you were given in the other thread.
Posted: Thu Oct 24, 2013 4:33 pm |
Just wanted to know can i drive with wynns in the engine without damaging it? Has anyone else did this method? Will it cause oil thinner causing more friction between engine components? Will it stop the oil circulating properly in the engine?
Posted: Thu Oct 24, 2013 4:54 pm |
How can you constantly drive for 15mins at 2000rpm? The revs will always be varied on your journey. It probably alters the oils protective qualities somehow
Posted: Thu Oct 24, 2013 5:07 pm |
I wouldn't use the flush stuff anyway. There's build up of carbon deposits in the engine, when you flush the engine these deposits can move and block things up. It happened to a friend at work, so my advise is not to bother and just change the oil and filter with good oil and a genuine filter
| You never really learn to swear until you learn to drive | |
Posted: Thu Oct 24, 2013 6:13 pm |
Trade Rating: +59
Just put sand in your engine. I heard that works quite well too.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Fri Oct 25, 2013 7:48 am |
ukskater01 wrote: |
I wouldn't use the flush stuff anyway. There's build up of carbon deposits in the engine, when you flush the engine these deposits can move and block things up. It happened to a friend at work, so my advise is not to bother and just change the oil and filter with good oil and a genuine filter |
That will happen on high mileage cars right? The mileage on my car is 67000. Is it still ok and go ahead with the flush?
I dont understand that people Reccomend to use engine flush in the sticky threads on this website forums yet some people oppose 2 it. Im confused?
Posted: Fri Oct 25, 2013 8:25 am |
There's no point in flushing it. With regular oil changes it's not necessary.
Posted: Fri Oct 25, 2013 4:25 pm |
Ok the jury has come to a verdict that engine flush is rubbish so i might as well return it back to halfords.
