Latest: sparrowdclxvi
Overall: 17139
Online Now [124]:
Visitors: 123
Today: 25972
Total: 113398280
Forums › The Car › 206 Talk › Plug/connector hanging?
karimali831
PostPosted: Tue Oct 01, 2013 9:44 am Up
I have found a connector plug hanging from the offside front, anyone know what this is for and where it connects to? Couldn't find nothing. Confused
s16.postimg.org/m95kj7...G_2123.jpg
Thanks.
206 GTI 180
PostPosted: Tue Oct 01, 2013 9:52 am Up
Not the foglight is it?
PostPosted: Tue Oct 01, 2013 1:28 pm Up
Indicator? Can you see the wiring numbers?
Get it tucked away in the mean time, the aux belt is likely to chew it up.
PostPosted: Tue Oct 01, 2013 1:58 pm Up
Do you use your horn much?
Air con working?
Ethernet?
PostPosted: Tue Oct 01, 2013 2:49 pm Up
Wrong place for horn, wrong colour plug and connector type for aircon.
PostPosted: Tue Oct 01, 2013 3:09 pm Up
I don't think so Steve, I know both those quite well and it could well be either of them (2-pin PAS connector with locking brace). Of course I could well be wrong as they're used on other things too around there.
PostPosted: Tue Oct 01, 2013 4:11 pm Up
Washer pump uses a two pin JPT plug like that.
PostPosted: Tue Oct 01, 2013 4:35 pm Up
Air con on mine is a yellow long think connector, slides and fits onto the aircon. Good call Edward. Does the emission canister have one fitted?
karimali831
PostPosted: Tue Oct 01, 2013 7:03 pm Up
I have just checked, everything working except all fog lights. This was just after body work repair.. and the front bumper was removed. They must of forgotten to put connector back on. Faults are randomly appearing on the MFD and cluster when using the light switch. (abs fault, anti-pollution fault, brake fault, ESP/ASR not functioning, "stop" flashing and speed needle to zero).
Will check connector tomorrow, thanks for replies. Cool
206 GTI 180
