Posted: Sun Oct 13, 2013 1:39 am |
Hi all,
As I drove out of my garage I noticed a tiny oil drop on the floor.
After looking underneath the car I could see some residue and another drip hanging on the passenger (left hand side), closer to the front wheel.
I have attached a photo to help explain my scenario.
Does anyone know where this is coming from or what it could be?
Posted: Sun Oct 13, 2013 2:45 am |
It might be power steering being on that side of the car, I had an oil leak on mine but was more central and turned out to be the rocker cover gasket had gone
Posted: Sun Oct 13, 2013 2:57 am |
Post updated - have mentioned it is on the passenger LEFT hand side.
Posted: Sun Oct 13, 2013 3:06 am |
As that is under the subframe, it could be coming from anywhere,
Posted: Sun Oct 13, 2013 4:51 am |
Looks like oil is getting into the subframe somewhere else. Could be from anywhere.
Posted: Sun Oct 13, 2013 6:58 am |
I had oil from the gearbox when the driveshaft seals went.
| You never really learn to swear until you learn to drive | |
