Latest: heikkisj
Overall: 17126
Online Now [43]:
Visitors: 42
Today: 8457
Total: 100206108
Forums › The Car › 206 Problems › electrical gremlins
electrical gremlins
tom2581
PostPosted: Sun Oct 06, 2013 2:07 am Up
roughly about 6-7 weeks ago, after driving to a mates i parked up, when i came to leave my car was dead, the central locking just about opened the doors, turned key the dash lit as normal but soon as you tried to fire it no electrics, so my mate tried to jump start me nothing ?
was as if there was no battery at all in car, was about to to call break down out when i noticed faint battery light on dash, then all of a sudden interior light came and dash lit as normal the clock had reset to french 1998 lol so i turned the key it fired but cut straight out as if fuel pump was off, so held foot on accelerator tried again and fired and as been running fine since until friday night...
i drive 32 mile a day for work, so i need car for work, on the way home friday night, i was on a dual carriage way luckily on my own, as i came off the island i noticed my ABS and handbrake light were illuminated, ive not long had brakes done so i'm thinking faulty ABS sensor, as i apporached next island i noticed my brake lights wernt working, normally see the window light reflect in rear view ? so i pulled onto sainsburys turned car off thinking may be it was a pot hole had set off abs light, but when i came to start car again it was dead like before so i thought great stuck here now, so i did exactly what i did before but i put side lights on turned key an opened door, after 5 mins the battery light came on and the buzzer to say door was open with key in ignition, couple mins later i got it started, drove to work yesterday and back no problems ??
no EML at all on both occasions, and battery was new feb-march last yr
i'm guessing battery is duff or a cell is dying, or could be the ngk plug fitted Confused any ideas lads and lasses
i'll post voltages up when i find me volt reader from the shed
thanx in advance
Tolkienfan001
PostPosted: Sun Oct 06, 2013 2:28 am Up
Trade Rating: +13
Have you checked the Earth strap?
2005 1.4 16v Sport
Check out my 206 here!
tom2581
PostPosted: Sun Oct 06, 2013 3:00 am Up
not yet, i'm guessing its the negative lead from battery to gear box , gonna need to dig ramps outta garage to now lol
Tolkienfan001
PostPosted: Sun Oct 06, 2013 3:16 am Up
Trade Rating: +13
Yea thats it. You don't need a ramp to check it though?
2005 1.4 16v Sport
tom2581
PostPosted: Sun Oct 06, 2013 4:05 am Up
ok do i need to disconect the terminals to check
Tolkienfan001
PostPosted: Sun Oct 06, 2013 4:29 am Up
Trade Rating: +13
Just look to see if it is corroded or split anywhere.
2005 1.4 16v Sport
tom2581
PostPosted: Sun Oct 06, 2013 6:00 am Up
had a look cable looks pretty good cant see where it connects to gearbox bloody sun making it hard to see, but its slightly exposed battery end looks stretched
found me multimeter also looks like battery and possibly alternator needs replacing with engine off its reading 12.07v with engine running its 14.44v so its charging but under load with headlights and heater on it down to 14.33v
so gonna go get a new battery terminal sort the earth cable out cause its exposed
tom2581
PostPosted: Sun Oct 06, 2013 6:02 am Up
btw the amp fuse isnt connected either no amp as some scum stole whilst in storage
PostPosted: Sun Oct 06, 2013 6:18 am Up
Looks like your battery is on the way out if it's showing 12.07v at rest. Should be reading about 12.65v at 100% charge. Yours is about 25% full.
tom2581
PostPosted: Sun Oct 06, 2013 6:26 am Up
guessed as much its about 19 month old had 3yr warranty on it but as usual cant find receipt Sad
tom2581
PostPosted: Mon Oct 07, 2013 9:56 am Up
new battery fitted reading 12.65v at standstill, terminal block replaced slightly different readings at idle and with load on but i'm assuming thats because the alternator hasnt gotta work as hard to charge battery up at the moment at idle its reading 14.33v dropping to 14.28v under load
car sound alot healthier on start up took it for a run checked battery when i got home reading 13.45v and slowly drops back down to 12.65v
so touch wood only money i'll need to spend is on fuel , antifreeze and some new tyres
