Online Now [1134]:
Visitors: 1133
Today: 373750
Total: 151487760
Forums › The Car › 206 Problems › ***HeLp*** Engine Management issue
sheerness
PostPosted: Thu Oct 10, 2013 2:48 pm Up
Hi there 206 Friends.
I Am in need of a little help, got a 1.6 8V Roland garros (2000) WReg
I Have an alternator has died (need to get new one) but had no choice in driving back home from neath south wales to sheerness Kent, i managed to get on the M25 till the car died, so called the aa who was there within 10 mins, the plan was to to stick another battery on and he wall fallow, but for some reason the dreaded management light has come on and can not restart the car, so it was a free lift back home, i charged my battery over night put it back in the car and that light is still on and cant start the car, plenty of battery so can someone think if what it could be? im so stressed with this car now please please someone out there "Help ME"
Kind Regards
Dom.....
Rolling Eyes Confused Shocked
PostPosted: Thu Oct 10, 2013 3:13 pm Up
Check the earth. Didn't the AA fault read it?
PostPosted: Thu Oct 10, 2013 3:14 pm Up
How go you know the alternator is dead? I can't imagine you would get 50 miles with a dead alternator.
sheerness
PostPosted: Thu Oct 10, 2013 3:54 pm Up
because it was not charging, and also the battery light stayed on, i didn't use the radio use any lights apart for braking 2 or 3 time because i had to.... i have put pp on there but not understanding what the codes are, ect i have taken some pic's if i can work out upload them here,?
Kind Regards
Dom.....
PostPosted: Fri Oct 11, 2013 1:49 am Up
Just write the codes up on here. Use photo bucket to upload pics.
southwestchap
PostPosted: Fri Oct 11, 2013 5:58 am Up
get the codes up as said. could be a number of things. One time when we had a 1.4 that wouldn't start it turned out to be the crank shaft sensor was dodgy
sheerness
PostPosted: Fri Oct 11, 2013 9:29 am Up
Hi there guys thank you for all your help so far,
below is a link to the pictures of PP2000 with errors on the car,
there may be a few repeated pictures on there, if so i'm sorry my head is in the shed with it all at the moment, Sad
please have a look at the pictures and give me some advice on what the problem is and where to find it,
Again thank you for all your help and input!!
Kind Regards
Dom & Roland Garros lol...... Smile
s1293.photobucket.com/...1/library/
PostPosted: Fri Oct 11, 2013 10:20 am Up
Can't see the pictures clearly.
sheerness
PostPosted: Sat Oct 12, 2013 8:03 am Up
Hi there again
i have just done some screen grabs hope you can see it better, i have done a BSI reset & Still have the problem, nothing has changed,
s1293.photobucket.com/...slideshow/
Kind Regards
Dom.....
PostPosted: Sat Oct 12, 2013 1:14 pm Up
Doesn't look good tbh. Sounds like a knackered bsi.
sheerness
PostPosted: Sun Oct 20, 2013 3:11 pm Up
i have another bsi & ecu arriving here on Tuesday, i got that feeling that the ecu/bsi spiked when the car run out of battery power ;(
KR
Dom.....
sheerness
PostPosted: Tue Oct 22, 2013 8:38 am Up
Hi there friends,
ok new BSI & ECU Replaced and still getting Wire 8628 shortened to positive Repair the harness,
can someone please tell me where this is??? i have also replaced the ecu relay under the ecu All fuses have been replaced, still got engin magagment light on and car the car still will not start, *****HELP*****
Regards
Dom.....
PostPosted: Tue Oct 22, 2013 8:59 am Up
8628 or 8272?
8628 or 8272 as stated in the picture?
From looking at the picture, it's possible that it's linked to the immobiliser. Quite common for the aerial to need replacing at the ignition barrel.
sheerness
PostPosted: Tue Oct 22, 2013 9:15 am Up
opsssss its 8272 my mistake,
also it is a replacement key barrel and key,
kind regards
Dom.....
