Online Now [494]:
Visitors: 494
Today: 43290
Total: 142426116
Forums › The Car › 206 Problems › Any help?
Any help?
dan1995206
PostPosted: Wed Oct 30, 2013 7:15 pm Up
Hi, sorry if it seems like I'm going to moan but I'm having a few problems with my pug which is driving me crazy and making want to swap it in! Firstly I have developed a load tire noise although I am running budgets so I may have answered my own question there! Secondly my central locking is playing up it sometimes doesn't lock and the front left door flashed to say it's open when it's not? I have annoying problem that it constantly is steaming up snd I always get water on the inside of the windscreen. Any suggestions or advice would be great as my insurance is up soon snd I want a project car but wondering if this is to far gone?
Peugeot 206 1.4 Diablo Red
tom2581
PostPosted: Thu Oct 31, 2013 5:28 am Up
windscreen seal could be letting water in, 1st thing 1st is to change pollen filter if thats damp, it could be sucking moisture into the cabin when blowers are on, i';ve had this problem on other cars but not the pug as of yet, as for central locking at the door saying its open at a guess i'd say new door switch, and locking motor ??
only guesses but hope i'm of some help
VorTechS
PostPosted: Thu Oct 31, 2013 7:35 am Up
Staff - Vortechs
Condensation on the windscreen could well be being caused by a lack of the white insulation material behind the door cards.
Seatock789
PostPosted: Thu Oct 31, 2013 3:03 pm Up
I had the same problem with the central locking issue on mine. It seems like the only solution is to replace the door lock actuator, I bought my replacement off ebay for £10 inc postage, just make sure you get the right one as i believe there are 2 different plug units, unfortunately the only way to do this is to get inside the door and have a look, be aware the the plug can be a b1tch to get off.
Took me about 1/2 hour to replace mine. Looks a complicated job at 1st as the door lock itself needs to come out and then everything needs to be lined up to work. My advice is to take pictures as you go along.
PostPosted: Thu Oct 31, 2013 4:19 pm Up
Well for the tires,try a good brand,and not a cheap set,this way the noise will go away,about the central locking problem,you need to replace the lock itself,the one that doing the problem (front left ) in your case,and it will work great,as both fronts are masters.
About the steaming from the front windscreen when heater is on,I believe that your heater matrix is on it way out,check for water in the floor,or lose of your coolant.
PostPosted: Fri Nov 01, 2013 3:29 pm Up
Steaming windows can be many things but is nearly always related to excess moisture inside the vehicle. This gets picked up in the warm air and then settles onto the cold windscreen glass. So check for:-
Damp mats. Where is the water getting in if they are damp. Are window or door seals leaking or have your mates spilt a drink?
Does your car have the Roland Garos sun roof? These get quite wet with condensation on the inside in cold wet weather over night. When you start to drive that moisture gets moved by the circulating air and settles on the windscreen. The only fix is to wipe that that sunroof dry when you first get in the car and leaving the sliding blind pulled back rather than covering the sunroof also reduces the condensation.
Blocked pollen filter. This prevents dryer outside air getting into the car so you only circulate damp air.
Heater setting set to recirculate air. Do not do this as your own breath contains a lot of moisture that will build up in the air and settle on the cold windows.
As already mentioned leaking radiator matrix.
dan1995206
PostPosted: Sat Nov 02, 2013 1:34 am Up
Thabks guys will definitely change the actuator.
dan1995206
PostPosted: Sat Nov 02, 2013 4:24 am Up
Update****
My door lock pin on the front left door will not go down at all its stuck? Is there a guide on here on how to change the actuator as I can't find one?
