Latest: Mr-Koekwaus
Overall: 17125
Online Now [268]:
Visitors: 267
Today: 31579
Total: 99649607
Forums › The Car › 206 Problems › Galletto 1260 not reading 2.0Hdi ECU
samd864
PostPosted: Thu Oct 10, 2013 3:00 pm Up
Just bought a Galletto 1260 off ebay
www.ebay.co.uk/itm/320...1439.l2649
I was trying to read the ECU of my 206 2.0 Hdi using the software.
The plan was to buy a stage 2 map from pro_steve When i click the read ecu button i get error -1 and the ecu read fails.
Hope someone has some ideas on this i have tried several times and get the same error every time.
PostPosted: Thu Oct 10, 2013 3:10 pm Up
Checked your ecu number?
PostPosted: Thu Oct 10, 2013 4:28 pm Up
Diesels only became EOBD compliant in 2004. If your car is pre 2004, then the protocols may not work with the software that you have.
samd864
PostPosted: Thu Oct 10, 2013 4:49 pm Up
Mine is an 04 plate, is there any software that you can recommend that I use? Thanks.
PostPosted: Thu Oct 10, 2013 5:04 pm Up
I use the Elm327 and Palmer Performance software. Used it on a 2000 diesel with no problems.
Somewhere I have a diagram of which pins should be connected for ISO VPW or PWM. You may be able to change the settings in the software. I'll dig it out tomorrow and post it up.
cartoonhead
PostPosted: Thu Oct 10, 2013 6:54 pm Up
did you install the drivers for the lead ?
samd864
PostPosted: Fri Oct 11, 2013 3:35 am Up
It seemed to install the drivers on its own and appeared as a com4 port on my windows 8 laptop. will try with xp later.
PostPosted: Fri Oct 11, 2013 3:38 am Up
Have you got the ignition on?
samd864
PostPosted: Fri Oct 11, 2013 5:57 am Up
I plug the cable in launch the software and then turn on the ignition.
PostPosted: Fri Oct 11, 2013 8:10 am Up
I would plug it in and then turn ignition on.
PostPosted: Fri Oct 11, 2013 9:05 am Up
Check in the software settings to make sure that your protocol is set for ISO. It may be different with a programming lead, but worth a try.
I would have thought it would adjust automatically for the vehicle it is connected to, but not having used the software, I couldn't tell you.
I'd also try it on XP as the advert says
Quote::
This tool also requires Windows XP 32bit or earlier - while it may work, we do not support it on Vista or Windows 7 or on any 64bit operating systems.
So at a guess it won't work on Windows 8
rlees85
PostPosted: Mon Oct 14, 2013 9:09 am Up
I'm sure I read somewhere Galetto requires Windows XP. If you have access to an XP laptop give that a go first. I am guessing you have the EDC15C2 ECU? If so all should work...
If your local to Macclesfield (long shot I know haha) your welcome to have a go with my KWP2000 that I use to read/write my 2.0 with
gpvecchi
PostPosted: Mon Oct 14, 2013 9:39 am Up
May someone share latest Galletto 1260 drivers?
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
samd864
PostPosted: Mon Oct 14, 2013 1:13 pm Up
Only about 120miles away Laughing I have got it to run on my XP laptop. Thanks for the offer anyhow.
