Latest: elelectricistadeMateo
Overall: 17127
Online Now [77]:
Visitors: 75
Members: 1
Today: 14084
Total: 100412276
Forums › The Car › 206 Problems › flat spot gti180
flat spot gti180
paulspug
PostPosted: Thu Oct 03, 2013 8:08 am Up
well seems ive picked up a flat spot in the rev range.
car pulls well in gears until i change to 5th at around 115mph then just wont pull anymore.
ive checked plugs, vvt and all seems well.
The car has only done 39k and if FSH.
I cant remember at what revs it was as was on a airfield, as watching out for pot holes,(racing a cc which btw was pretty fast itself)
Have i missed something obvious?
The car has scorpion cat back and k+n panel filter, but is not remapped.
Advice most welcome Wink
Uz
PostPosted: Thu Oct 03, 2013 8:45 am Up
Something must be wrong because mine at 115 down Shakespeare mile drag it just keeps going and miles done 80k... when was the last time it was serviced..?
mattymj
PostPosted: Thu Oct 03, 2013 11:10 am Up
Has the engine management light been on? How do u know the vvt is fine just by looking? What plugs are in it. Should be bosch
daykes1
PostPosted: Thu Oct 03, 2013 11:49 am Up
forgive me if this sounds silly but have you done the simple things like coils, cleaned map sensor/throttle body, fuel filter etc?
mattymj
PostPosted: Thu Oct 03, 2013 1:49 pm Up
Can try all the above except don't go looking for a fuel filter, it's built into the tank
Schumi
PostPosted: Thu Oct 03, 2013 6:13 pm Up
Everybody said that but it doesnt. Mine and my 3 friends car have fuel filter under car near fuel tank. It can be change.
2005 206 RC RED
mattymj
PostPosted: Thu Oct 03, 2013 6:50 pm Up
Can you get a picture of its location? Maybe the rc is different
imjeeves
PostPosted: Fri Oct 04, 2013 3:18 am Up
Its on the side of the tank its not internal. It can be changed
mattymj
PostPosted: Fri Oct 04, 2013 7:33 am Up
I see. I must have another look. Peugeot parts have assured me it doesn't have one!
paulspug
PostPosted: Fri Oct 04, 2013 9:00 am Up
hi
thanks for all the replys.
yes have checked all the obvious/filters plugs(bosch)/throttle bodie cleaned / vvt was cleaned although other than replacing i would not know how to check it.\even checked for brake binding on each wheel but that seems fine.
The plugs are all sparking well , and the engine is fine until tht speed, i was told the filter was in the tank , but i shall go check when im off work (n/s till tuesday Sad
Guessing i'll have to strip it all down when i finish tue - just to make sure ive not missed something.
Other than that i'll be seeking a pp200 to check it all
Thnx all
paulspug
PostPosted: Fri Oct 04, 2013 10:01 am Up
aha
just been out before work to have a quick strip down of the obvious.
i have come across a two way valve that sits in the inlet manifold. one hose to the airbox -valve which has a electric connector-a hose to the manifold.
There is oil in hose the side that goes from the manifold to valve.
Not had a chance to do anything about it as gotta leg it to work real soon, but looks like i gotta strip at least the intake off/fuel rails etc to get a better assesment of it.
could this be my problem?gti 180.
mattymj
PostPosted: Fri Oct 04, 2013 10:27 am Up
Thats probably just some sort of breather. I know which hose u mean. Im not sure what the electric connection is for. Im sure u can unclip the whole pipe from the inlet end and have a clean. Take a ride down to Norfolk. I dont mind taking a look
paulspug
PostPosted: Sat Oct 05, 2013 9:53 am Up
Thats very decent of you, thanks,
i dont finish work till tue morning, so will be in touch after
paulspug
PostPosted: Thu Oct 10, 2013 2:25 am Up
Thanks mattymj, but seems ive stumbled across the problem.
Was fitting a polybush lower engine mount and i noticed a lil bit of carbon around the cat exhaust flange.
On inspection , it seems it has been blowing slightly.
Will clean it up next week as ive got to go back to work early this week :/
I can only assume this has effected my problem , but wont know till later.
May well visit you next week if the problem persists, but will pm you 1st ofc
mattymj
PostPosted: Thu Oct 10, 2013 3:26 am Up
Ok no worries. Hope that solves the problem. It's like finding a needle in a haystack sometimes
