Forums › The Car › 206 Problems › Removing engine, box and subframe in one? |
Posted: Fri Oct 18, 2013 11:11 am |
Hello folks.
Advice please? I have a number of jobs that I'd like to do on the front of my gti138. Clutch, belts, weld manifold, lower arms, check and refresh suspension.
I could do each job one at a time, but is it feasible to remove the engine and box complete with suspension, driveshafts and hubs in one lot?
Would be nice to take my time in a warm garage!
Any experience appreciated.
Danny
Posted: Fri Oct 18, 2013 12:57 pm |
No point. Just one bolt holds the engine to the subframe so makes life easier to take every off separately.
