Latest: flipflap
Overall: 17140
Online Now [188]:
Visitors: 187
Today: 22051
Total: 113727219
Forums › The Car › 206 Problems › the ecu has not replied
sheerness
PostPosted: Tue Jan 08, 2013 7:17 am Up
Hi again guys, I Guess you are getting fed up with me and my posts, but i have nowhere els to turn to, in my previous post I Am having a few problem in getting access in the the AIRBAG ecu, I Have a light in my dash that says there is a problem with my side airbags (I dont have any) i am using PP2000 global test run fine, but when i am trying to get in to the ecu to change settings to turn off side airbag i get "the ecu has not replied, can someone out there please help me with this or even TEAM viewer and have ago your self's maybe i am missing something out, I have removed windows 7 and installed XP and the problem is just the same,
Thanks in advance
Dom..... Confused
PostPosted: Tue Jan 08, 2013 10:19 am Up
I cant remember where, but to can go to ECU and select your ECU manually. Have you done that? I had to do it on mine.
Mattie-RS
PostPosted: Tue Jan 08, 2013 11:31 am Up
Im sure you can't alter the setting on the Airbag ecu, I did say this in all your other threads
sheerness
PostPosted: Tue Jan 08, 2013 12:46 pm Up
yes I have tried this but I get an error that the ecu has not replied Sad
sheerness
PostPosted: Tue Jan 08, 2013 12:50 pm Up
Hi thanks for that,
people have said it can be done hence why I am still trying to get this sorted,
Dom.....
Dillon
PostPosted: Tue Jan 08, 2013 1:10 pm Up
Staff - Dillon
Is this the ecu that came with the car? Or have you changed the seats, what is the history of the car has it had an accident? I am asking just in case or mainly because I cannot be assed to read the other threads Razz iirc if the ECU has side air bags turned on you need to plug them in! It cannot be recoded or turned off. Same with deployment once it has fired airbags it is useless. Sounds like a dodgy repair or the original seats have been replaced.
sheerness
PostPosted: Tue Jan 08, 2013 1:40 pm Up
the airbag ecu is a replacement as the original became faulty (airbag light was flashing + a solid side airbag light) the flashing light has now gone but still have the solid one.. the car has the original seats and do not have airbags, there are 2 airbag driver and passenger, 2 seat belt pretension which I have replace today,
I cant get the ecu to respond to turn off this light, (turn off the side airbag option)
Dom.....
karimali831
PostPosted: Tue Jan 08, 2013 2:08 pm Up
can't you just remove the bulb if that's all you want to do?
206 GTI 180
PostPosted: Tue Jan 08, 2013 2:18 pm Up
If normal operation of the seat airbag system is that the bulb lights on first turnning the key and then extinguishes after a few seconds a sharp eyed MOT tester will fail the car.
Inoperative or iluminated warning lights (air bags, seat belts, ABS etc.) is now an MOT failure.
Well that is my understanding. It could be just illuminated ones.
Dillon
PostPosted: Tue Jan 08, 2013 3:50 pm Up
Staff - Dillon
Where did the replacement come from? Sounds like the wrong one has been fitted needs to be the type without side air bags.
bezford
PostPosted: Tue Jan 08, 2013 7:24 pm Up
u still have an airbag lite beside this??? so it----------(?problem lite)___(airbag words)___(sumthing else)--
????????is this the position of your problem lite????????these above but on the far left of the clocks binnacle????
IF SO---i do have this lite on mine just its in red...and it goes off?
R.HYDE
PostPosted: Sun Oct 20, 2013 11:02 am Up
You do realise that is just because a bulb is in there when it shouldnt be?
Take the bulb out and forget
gazza82
PostPosted: Mon Oct 21, 2013 3:39 am Up
Not sure if it's a bulb .. often the safety lights are LED's mounted to the circuit board so it can't be removed ... for obvious reasons.
tsotd
PostPosted: Mon Oct 21, 2013 8:30 am Up
i vote for taking the bulb out, if you dont have side airbags then i cant see there being a problem even with the MOT
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
PostPosted: Mon Oct 21, 2013 8:47 am Up
Nice thread revival Addaz.
Hopefully the OP has got this sorted in the last 9 months, although it would be nice to know what the final solution was.
