Latest: Andyblue64
Overall: 17123
Online Now [331]:
Visitors: 330
Today: 84421
Total: 98355974
Forums › The Car › 206 Problems › fuel gauge fault
fuel gauge fault
kenzie
PostPosted: Sun Oct 20, 2013 3:06 pm Up
hi everyone just brought a 2.0 hdi today and the fuel gauge has a fault. when i turn the car off the needle goes to just below half way then stops. you put fuel in and the needle does move but it seems its show empty just below half and the light does come on.
any ideas?
Red 206 GTi
Revenge is like a ghost. It takes over every man it touches. It's thirst cannot be quenched, until the last man standing has fallen. The world's men of action will look and wonder...how it came to this. You may be able to destroy me, but the beast will eventually come for you
deacon49
PostPosted: Sun Oct 20, 2013 5:23 pm Up
i had the same fault on my 2.0 hdi which i have just got about 3 weeks ago. Im not saying this is how to set it but it made my gauge more accurate than empty being at a quarter tank.
Firstly i took the surround of the speedo clocks and pulled them out from the dash enough so i could get the clear plastic front off. i removed the clear front and placed the clocks back in position. i turned on the ignition so the fuel gauge needle goes up. then go in to the sender which is under the back seat drivers side and unplug it. after a few seconds the fuel gauge needle should drop to where (in my opinion) it would register no fuel. take to table spoons to your gauge and carefully use the spoon end on either side of the needle and gently work it loose. remove it and then carefully place it back on in the empty position. i did this and now my fuel light comes on just under a quarter tank. much better than coming on at half a tank lol.
Hope this helps Smile
Will
kenzie
PostPosted: Mon Oct 21, 2013 1:41 am Up
Hi mate yes thanks for your reply I shall try this when I get a spare hour or two. Thanks. again
Red 206 GTi
PostPosted: Mon Oct 21, 2013 2:40 am Up
Reboot the BSI and if that doesn't work, go to the dealer for a software upgrade. Quite a common issue on the 206.
Brimming the tank can also work, but not guaranteed.
kenzie
PostPosted: Mon Oct 21, 2013 11:44 am Up
Yeah heard about this bsi thing. What does it stand for mate and how do you do this reset? Is it easy?
Red 206 GTi
DREWDEN
PostPosted: Mon Oct 21, 2013 12:24 pm Up
www.bba-reman.com/cont...ot_process Very Happy
206 2ltr Hdi glx 53 plate
kenzie
PostPosted: Mon Oct 21, 2013 12:41 pm Up
Wicked cheers mate will this work on a x plate (2001)
Red 206 GTi
PostPosted: Mon Oct 21, 2013 1:43 pm Up
No, that's for the multiplexed (or very similar to it)
The pre-plex/non-plex method can be found in this thread
