Latest: DanDan17
Overall: 17128
Online Now [58]:
Visitors: 57
Today: 46753
Total: 100474412
Forums › The Car › 206 Problems › rad cooling fan
rad cooling fan
2stroke
PostPosted: Tue Dec 03, 2013 8:25 am Up
the fan on my peugeot 206 1.1lx year 2000 only cuts in at high speed. should it not also run at low speed ?
I don't have the relays and resistor that are suspect on some models ?
fan at fault ? Question
PostPosted: Tue Dec 03, 2013 8:38 am Up
Do you have aircon?
2stroke
PostPosted: Tue Dec 03, 2013 11:16 am Up
nay, no aircon ?
PostPosted: Tue Dec 03, 2013 1:25 pm Up
Pretty sure the two speed fan only came on models with air con. Someone will correct me if I'm wrong.
PostPosted: Tue Dec 03, 2013 3:51 pm Up
Are there two relays? Sound like one or the wiring to one might be past its best.
2stroke
PostPosted: Tue Dec 03, 2013 4:13 pm Up
just checked with a mate, he said the rad fan on a1.1 lx are single speed. However my fan is past its best sounds like a bearing starting to go when operating.... can they be rebuiilt ?
