Online Now [987]:
Visitors: 986
Today: 193052
Total: 152586777
Forums › The Car › Request a how-to › How to replace Spark Plugs on a 206 1.4 8v TU3A Engine 2006?
very_452001
PostPosted: Thu Oct 24, 2013 9:19 am Reply with quote Up
Also is it quicker to replace the air filter first or spark plugs first?
Thanks,
very_452001
PostPosted: Thu Oct 24, 2013 10:14 am Reply with quote Up
Unbolt the coil pack lift off, use a spark plug socket, undo the the spark plugs.
Replace and refit coil pack. Easy 10 minute job.
very_452001
PostPosted: Thu Oct 24, 2013 11:23 am Reply with quote Up
Nice one, thanks.
very_452001
very_452001
PostPosted: Tue Nov 05, 2013 11:43 am Reply with quote Up
I attempted the task today.
Silly question, can I just pull the spark plugs out or unscrew them?
What mm Socket/Spanner do I need to get the spark plugs out?
The angle to access the spark plugs looks like a 45 degrees so how do I get them out without the socket/spanner bar conflicting/touching throttle body housing?
Finally I bough Bosch Super Plus spark plugs, what mm do I need to tighten them?
very_452001
  Quick Reply
Username:
Message:
Quote the last message
