Latest: DanDan17
Overall: 17128
Online Now [58]:
Visitors: 57
Today: 21724
Total: 100419894
Forums › The Car › 206 Problems › wheel balance problem
deano9621
PostPosted: Sat Nov 02, 2013 11:50 am Up
Had this problem for a while now,fitted coilovers and had to fit some spacers and since then i get wheel vibration...the spacers are just plane flat one's they don't have a lip for the wheel to mount on...which is what is needed,i was told by a wheel specialist?..do i need to fit 10 mm spacers (hubcentric) with longer wheel bolts to sort the problem or just fit some longer wheel bolts to make up the 5mm i lost with the spacer's...getting fed up now...any help cheers Sad
french forever
PostPosted: Sat Nov 02, 2013 12:05 pm Up
well you answered your question,since the one you fitted is plane flat,that makes the vibration to happen,as the wheel itself is not based on the (hubcentric),which take the load off the bolts :),but for what you have now,all the load is on the bolts,and I don't imagine how you left your old bolts on with spacers on,as you SHOULD use longer bolts,but not too long,make sure to calculate it.,and your problem will be SOLVED Very Happy
deano9621
PostPosted: Sat Nov 02, 2013 12:39 pm Up
Many thanks for your help,i will find some 10mm spacer's hubcentric with longer bolts and will hopefully sort the problem cheers Deano:)
french forever
PostPosted: Sat Nov 02, 2013 12:41 pm Up
You are most welcome Smile ,it will solve it Smile
