Latest: heikkisj
Overall: 17126
Online Now [61]:
Visitors: 60
Today: 10678
Total: 100383419
Forums › The Car › 206 Problems › P0351 code
P0351 code
Jonah
PostPosted: Wed Sep 25, 2013 4:44 pm Up
Hi all, this is my first post but have read loads about people dealing with a P0351 code since my own 180 is throwing one out.
The physical symptoms are engine sounding and running lumpy after about 15 minutes, and loss of power. Dashboard also reads "antipollution fault".
As I said I've read loads of posts about this and when I chuck on my code reader it says there is a circuit malfunction in the number 1 coil, which basically means there's no electricity going to the spark plug in that cylinder.
I have also noticed my car's running the dreaded NGK plugs.
I'm going to replace the coil pack and put in some Bosch super 4s and see if this solves my problem. Fingers crossed.
iainlovatt
PostPosted: Thu Sep 26, 2013 8:10 am Up
Should you need it we have a 180 coil pack from a 180 that we broke.
Engine was running perfectly.
(My Garage)
Jonah
PostPosted: Tue Nov 05, 2013 4:40 pm Up
It's been over a month now since I have replaced the coil pack and plugs, and I have covered hundreds of miles since. The problem seems to be cured. Happy Days. Thumb Up
