Online Now [1577]:
Visitors: 1576
Today: 65240
Total: 152108663
Forums › The Car › 206 Talk › Wiring single LED strip into left footwell (HELP) !!!!!!!!
Forum Index › 206 Talk
adamscfc
PostPosted: Thu Jan 30, 2014 10:11 am Up
Hi guys ,
Im wiring a single strip LED in my left footwell , ive stuck the LED on the underside of the glove comparntment and ive ran a short amount of wire back into MY ASH TRAY below where the little ash tray is im guessing these are NEG & POS , so the lights will come on when side lights and headlights on but i dont want that does anyone know what sort of with i need to control as when my lights stay on i can switch my LED's on/off due to it being to bright whilst driving and draining battery ? Im guessing its a 2 way switch just power out from the ashtray light into my switch and the wire out to my LED's.
Thanks guys
206 HDi 1.4 Blue
adamscfc
PostPosted: Thu Jan 30, 2014 10:12 am Up
***Anyone know what sort of switch***
206 HDi 1.4 Blue
commandosqueak
PostPosted: Thu Jan 30, 2014 10:19 am Up
spst switch with a inline fuse wired into the cig lighter would be fine. just make sure you do the connections properly and take the battery off first!!!!!!
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
adamscfc
PostPosted: Thu Jan 30, 2014 10:33 am Up
Okay thanks pal , can i not just wire it off the ashtray light through a rocker switch or not ?
206 HDi 1.4 Blue
commandosqueak
PostPosted: Thu Jan 30, 2014 10:45 am Up
yeah you can do. as long as you have a 12v dc positive and negative then all is good. just make sure the LED's are wired the correct way round as they are polarity sensitive.
adamscfc
PostPosted: Thu Jan 30, 2014 10:57 am Up
Yeah mate just bought a simple 2 spade connector 12v rocker switch , and yeah matw i will do just been messing about just testing things. Alls good thanks for the help.
206 HDi 1.4 Blue
