Latest: heikkisj
Overall: 17126
Online Now [453]:
Visitors: 452
Today: 31201
Total: 100364157
Forums › The Car › 206 Problems › Spare wheel cage
Spare wheel cage
stonster
PostPosted: Sun Nov 18, 2012 7:35 am Up
I'm sure this has been answered before... but I couldn't find it! Can you fit a normal size wheel/tyre in the spare wheel cage? I'm fed up with the space saver... I'm on 14" wheels but I do have a towbar fitted. Anyone done it?
stonster
PostPosted: Sun Nov 18, 2012 7:37 am Up
yes. normal 15" alloy no problem at all
stonster
PostPosted: Sun Nov 18, 2012 8:02 am Up
Thanks, does the jack still fit in? And does it sit lower, snd risk scraping on stuff at all?
stonster
PostPosted: Sun Nov 18, 2012 8:05 am Up
you have to lower the cage a bit but it won't scrap.
PostPosted: Sun Nov 18, 2012 8:11 am Up
Just stick the wheel in the boot. Keeps in better condition like that.
stonster
PostPosted: Wed Nov 27, 2013 5:38 am Up
I can confirm this works with a 14" and with a towbar as well and you can fit the jack in
stonster
