Latest: tc.206
Overall: 17147
Online Now [69]:
Visitors: 68
Today: 26487
Total: 116522962
Forums › The Car › 206 Talk › 206 injectors
206 injectors
scott1
PostPosted: Wed Dec 11, 2013 6:11 pm Up
hi my injectors have gone in my 1.4 lx and instead of putting standard ones back in i was wondering if there is any good performance injectors i could use?
omega
PostPosted: Thu Dec 12, 2013 5:38 am Up
what do you mean gone?
has some one pinched them?
you can get them cleaned which might be cheaper.
1245678
PostPosted: Thu Dec 12, 2013 8:08 am Up
Why? Are you maxing out the standard ones?
scott1
PostPosted: Thu Dec 12, 2013 5:11 pm Up
well i don't mean they have gone lol just seeing if there's better ones to replace them with as money is not to much of a problem because i wont be paying labor
PostPosted: Thu Dec 12, 2013 5:17 pm Up
You've missed the point completely. What do you expect to gain from bigger injectors? Have you done any other mods?
PostPosted: Thu Dec 12, 2013 5:20 pm Up
Unless youve maxed out the amount the standard injectors give, there is no point increasing the size of them
Bigger injectors with no other work give as much power as an ebay electronic 'supercharger'
scott1
PostPosted: Thu Dec 12, 2013 5:24 pm Up
there's no other mods to the engine at the moment and because when i had my civic i change the injectors to 500cc and had it made a hell of a difference so seeing if i could do something similar with my pug
scott1
PostPosted: Thu Dec 12, 2013 5:27 pm Up
ok thanks that's helped alot
PostPosted: Thu Dec 12, 2013 7:11 pm Up
500cc?! Was that running over 400bhp?! As that is crazily oversized, ignoring spray patterns.
PostPosted: Fri Dec 13, 2013 4:10 am Up
No, he's right I can confirm it does make a difference and it IS done a lot over here.
But usually the map is changed too etc..
PostPosted: Fri Dec 13, 2013 8:06 am Up
I dont see the point. Im only running 330cc for a turbo 1.4, do why you would want any bigger is beyond me.
Get it mapped and have the injectors maxed out if you have the supporting mods, or just fit 150 or so and then have it mapped. But still there is no point with a standard engine
scott1
PostPosted: Fri Dec 13, 2013 11:09 am Up
i have a feeling my car has already bin mapped as i haven't sin a 1.4 move like this but bigger injectors have helped in the past and was just hopping i could simply do the same with this car
PostPosted: Fri Dec 13, 2013 11:36 am Up
In a word. No.
