Latest: heikkisj
Overall: 17126
Online Now [72]:
Visitors: 71
Today: 15150
Total: 100229533
Forums › The Car › 206 Talk › What Oil?
What Oil?
James3107
PostPosted: Sat Nov 16, 2013 6:01 pm Up
So what oil do people use?
I use Shell Helix Ultra 5W 30 just wondered if this was doing any good to my car...
PostPosted: Sat Nov 16, 2013 6:08 pm Up
Total Quartz 10W40 as recommended by Peugeot.
5W30 may be too thin at higher temperatures to lubricate adequately.
Have a read of this guide from Oilman and it explains in a bit more detail.
www.206info.co.uk/Foru...57044.html
PostPosted: Sun Nov 17, 2013 1:55 am Up
Also depends which car it is!
PostPosted: Sun Nov 17, 2013 6:33 am Up
Shell Helix Ultra is excellent and I what I've been using exclussively for nearly 20 years now..
I found it's the best for the extreme conditions over here, and most people I know all agree on this.
I use 5W40 full synthetic in the 206 1.4i (TU3, 8-valve), and 5W30 on any other 16-valve engine which needs the thinner oil for the hydraulic tappets to work optimaly.
So yeah, depends what engine as Edward says but worth every penny even though quite expensive.
