Latest: Worthy967
Overall: 17143
Online Now [216]:
Visitors: 215
Today: 38609
Total: 115813508
Forums › The Car › 206 Problems › Help! Vibrations whilst accelerating!
LiamMiller
PostPosted: Fri Dec 06, 2013 1:14 pm Up
My 206 has been fine up until this morning, the whole car started vibrating and struggles to accelerate, but then has a sort of power surge every now and then. I am awaiting delivery of a new clutch but i don't think this is the problem. The engine management light is not on either, any help or feedback would be appreciated
2stroke
PostPosted: Fri Dec 06, 2013 2:10 pm Up
sounds like coil pack failure...
does it sound like a tractor ?
LiamMiller
PostPosted: Fri Dec 06, 2013 2:31 pm Up
Whilst struggling yeah it does, when i feed the power in gently it runs fine
2stroke
PostPosted: Fri Dec 06, 2013 2:40 pm Up
is there a funny smell from the exhaust whilst she is chugging ?
and is the exhaust getting very hot ?
LiamMiller
PostPosted: Fri Dec 06, 2013 3:23 pm Up
I'll find out, but ive looking into fauly coil packs and its showing most symptoms
2stroke
PostPosted: Fri Dec 06, 2013 4:01 pm Up
think you are a winner with your hunch, good luck
zoranm1976
PostPosted: Sat Dec 07, 2013 8:37 am Up
Same thing happened to me with first morning chils. I changed my coil pack 2 month ago together with plugs. Strange thing is that it is running fine when hot. I find out that coil plug extensions were loose. Probably bad rubber. I have to mention that I got second hand coil pack. I replaced extensions with ones from old coil pack and I think that the problem went away.
Mid 2002 206 1.4i XS LPG converted
doski
PostPosted: Sat Dec 07, 2013 1:02 pm Up
check your plugs also could be a cheaper fix if thats the problem
zoranm1976
PostPosted: Sat Dec 07, 2013 1:19 pm Up
Now I have RC8YCL Champion plugs less than 2 month old. Before I had Bosch super 4 fr78x. I had replaced in past years 3 sets of Bosch Super 4-s none of them lived longer than 1 year last set lived something like 3-4 month. I am suspecting that here in Bosnia and Herzegovina we get cheap turkish copies of Bosch plugs.
I get set for less than 18 pounds.
